Vortech AWAC vs air-air FMIC
Old Apr 21, 2005 | 06:25 AM
Stephen Max's Avatar
Ref:http://www.vortechsuperchargers.com/...oler_paper.pdf
This is a pretty interesting read, but it bothered me that they got such an improvement in power with the AWAC over the FMIC. It just didn't sit well with me. I finally realized why.
Look at figure 4 on page 11. They are comparing an AWAC that has a pressure drop of about .5 psi through it (at redline) against a FMIC that has a whopping 4 psi pressure drop! Then they increase the boost of the FMIC car by 4 psi in order to compare intake air temperatures at the throttle body for systems producing the same boost pressure. The extra 4 psi the FMIC car has to make results in more heat generated by the blower and lower efficiency of the SC system. So, of course the FMIC car is going to have higher intake air temperature (by 30 deg, see figure 5) and make lower power (342 hp vs 312 hp).
I contend that if you choose a FMIC that results in a 4 psi pressure drop across it, you are either a complete novice or you have a hidden agenda. A well chosen FMIC with well designed boost piping should result in about 1-1.5 psi pressure drop.
Old Apr 21, 2005 | 06:27 AM
SonicDust187's Avatar
Does this mean that you are going to install a FMIC soon?
Old Apr 21, 2005 | 06:40 AM
Not any time soon, but maybe eventually.
Old Apr 21, 2005 | 08:06 AM
You right, you don't really need it since you are running water/alcohol injection.
Old Apr 21, 2005 | 08:38 AM
Nealoc187's Avatar
SLOW
Slick marketing I must say. Not a good thing for those not as technically knowledgeable who are just looking for informational purposes. Perfect example of why you don't always trust what the manufacturer says.
Old Apr 21, 2005 | 09:44 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
they always doctor it in their favor. I have no problems with my custom air to water though.
My box is probably 3x the size of vortechs.
Another thing though.......
doesnt the air become more condensed with lower air temps? what affect does that have on their "results"?
Old Apr 21, 2005 | 10:04 AM
Bags's Avatar
VG Ridah's Biatch Hoe
good find and work
litch
123
Jan 4, 2024 07:01 PM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
i30krab
Mar 22, 2002 11:45 AM
