Fixed my boost problem
Old Apr 21, 2005 | 01:49 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
My wastegate would stay open at idle and I wouldn't see the boost that I dialed in on the BC.
The problem was that the vacuum source for the solenoid was from the intake plenum - which in turn went to the top of the tial WG. The side nipple of the WG went to the outlet of the turbo, resulting in a ever so tiny pressure difference. This caused the malfunctioning of the boost controller.
It's been months since I've boosted beyond 6 psi - which is what the WG spring will hold.
I opened her up to 12 psi today and i'm in love with the vq all over again.
Only problem is that she seemed awfully boggy. I did another run and the Wideband tells me that I start off at 10:1 a/f and drop down to 7:1 a/f by full boost. Looks like its time to tune.
The only worry I have is that already, the airflow map on my emanage is correcting the injectors from 555cc - > 260cc. I'm going to have to pull upwards of 15% fuel on the air flow map, and I'm afraid that my timing is going to be whack - can anyone else confirm that?
Old Apr 21, 2005 | 02:45 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Drop your base fuel pressure as low as you can.
The less you mess with MAF conditioning, the better IMHO.
Old Apr 21, 2005 | 10:18 PM
turbomax97's Avatar
So I've got the aem which drops down to 20 something psi... You're saying to drop the fuel pressure - while lowering the correction ratio that I've got w/ the emanage?
for example instead of 555cc's for the injector size - maybe 450 or what not?...
Old Apr 22, 2005 | 06:55 PM
IceY2K1's Avatar
Exactly, I'd drop the fuel pressure down(while monitoring AFR) as low as possible until you have atomization problems, ie rough idle, back it back a bit and then start reducing the injector scale factor. I'd probably say 20-25psi is as low as you should drop. Also, since you can monitor injector pulse width, I'd try and keep peak duty cycle around 80%.
Let your AFR tell you how much of each though.
Old Apr 23, 2005 | 11:09 AM
turbomax97's Avatar
i dropped fuel press down to 20 psi....up till the turbo spools to around 8 psi - im around 9.5 - 10:1, once i hit full boost - currently at 14 - it drops to 7.9:1. It's a little better than before - but now it's got me wondering if I have a leaky injector - again - or if i need to condition the maf some more.
Mar 12, 2020 12:06 AM
conansriver
Sep 11, 2015 10:26 AM
Colossus
Sep 9, 2015 05:46 AM
slowlifer
Sep 8, 2015 05:53 AM
Maxima30
Sep 7, 2015 06:13 PM
