E-bay GReddy style muffler..anyone here using it?
Is anyone here using the e-bay GReddy style muffler? If so, how does it sound and fit with an aftermarket B & Y pipe?
http://cgi.ebay.com/ebaymotors/ws/eB...MEWA%3AIT&rd=1
100% High Quality T304 Stainless Steel
Large Taper SUS Outer Curled Oval Rolled Edge Tip
Highly Polished SUS Oval Canister
10 Horsepower Increase
Increase Airflow and Reduce backpressure
Dimension: 2.5" Inlet / 4.5" Tip Outlet / 8 " Diameter / 23" Length
Originally Posted by I30_DRIVER
i have it it looks a bit diff then the pic but with a wsp y and that muffler sounds just like the greddy check out my cardomain
Id like to know more about this too!....I30 DRIVER, you say you have the knock off greddy style muffler and it sounds like a greddy?...did you have to weld it in?..it dosent just bolt in does it ?....do you have it with the stock Bpipe or something aftermarket ?...thanks for any input
I'm sure you'll have to have that welded on, but if someone was going with a custom bent catback this would be a good exhaust to put on. I might have to keep this is mind. Why pay SP2 money if you get get the same sound for much cheaper.
Hmm . .
do you have any sounds clips available?
I have some SP2 clips in my library I could host up to your clips so we can have a comparison.
Originally Posted by BlackCat
I take it this is a straight-through muffler?
If it is, I'm wondering if the 23" length helps tone the noise down to stock levels at all.
I have no clue if this is straight through. I am just trying to find a cheap SS solution that will sound decent, but I may just end up back with an oem style exhaust.
RWCreative
Sep 21, 2015 11:01 AM
But if you need to save money by all means have at it..
i agree with turd gen boy here..
