Fan mounting?
Old Apr 26, 2005 | 08:58 AM
WillMax95's Avatar
Fan mounting?
I'm thinking of mounting a fan on my amp, its getting quite hot now that its getting warmer out and i dont wanna see how hot it gets in the summer. Anyone have any flan ideas and how to mount. I'm running a Memphis 500D amp and it is mounted on the back of the seats in the trunk.
Old Apr 26, 2005 | 12:08 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Well, I would suggest two different ideas...
(1) Raise the smp off of the rear of the seat by using a longer mounting screw and some nuts underneath...this will allow cooler air to pass under the amp
(2) Purchase a computer fan or two and run them under the amp so it can better carry the heat away from the surface of the amp.
Lemme know how you make out!!!
Old Apr 26, 2005 | 12:25 PM
'96MaxGLE's Avatar
Here u go...this should help and work better than a computer fan and it will look a lot better installed too....
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
Old Apr 26, 2005 | 01:32 PM
djmaverick's Avatar
Runs with scissors
Yeah but how mych niose do they make. I just bought 2 computer case fans with blue LEDs that I ahve installed in my computer case and they are pretty much silent.
Old Apr 27, 2005 | 04:56 AM
WillMax95's Avatar
computer fans eh...one question, how do you hook them up, do u run a line to the battery or something, whats the easiest way to hook them up?
Old Apr 27, 2005 | 05:27 AM
SEmy2K2go's Avatar
Go BUCKS!!!
I was having the same issue with one of my amps. Below are two pics. I cut the end off the fitting for the computer fan and ran the black to the ground and the power lead to the remote turn-on for the amp. That way it turns on & off with the amp. It's probably not the best way to cure the problem, but my amp hasn't cut off since ( over a year now ).
These pics were taken while I was testing everything. Wires are hidden now.
Old Apr 27, 2005 | 06:56 AM
djmaverick's Avatar
Runs with scissors
You can hook them up to any 12v power. I would reccomend wiring them to a switch just so they aren't on all the time, unless that's what you want. If you run them directly to the battery, they will stay on all the time unless you switch them off. Usually not a good idea. SEmy2K2go has a good idea but see if you can wire it to something that only comes on when the car is on. (cig lighter, amp remote turn on etc...) just my .02 though.
Old Apr 27, 2005 | 07:29 AM
WillMax95's Avatar
hey SE, what did u wire your fan power to?
Old Apr 28, 2005 | 08:38 AM
jigga123's Avatar
If you have a solid 12 volts at the REM, you can wire it to a relay that will turn off and on with the amps only. To protect your hu, use a 1 amp inline on the remote wire. On the relay use a diode across terminal 85 to 86, when the coil collapses it can spike back to the hu. for the fans a 7.5 amp fuse should do it for 16 awg wire.
Old Apr 29, 2005 | 01:55 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Originally Posted by SEmy2K2go
...the power lead to the remote turn-on for the amp.
Old Apr 29, 2005 | 06:46 PM
WillMax95's Avatar
thanks guys, when i decided to acutally do this in the very near future, ill let ya know how it turns out
Old Apr 29, 2005 | 06:57 PM
merovi's Avatar
i've been having this problem and i just bought my fan of ebay for $5! i'm gonna set it up exactly how SEmy2K2go has it done
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Pnjboyzz
Oct 7, 2015 10:47 PM
sliptap
Sep 30, 2015 05:57 AM
