KS + Voltmeter = Early Warning System?
Old Apr 28, 2005 | 03:52 PM
killerVQ30DE's Avatar
I was reading my Haynes manual like a good maxima/cefiro owner should and it says that the voltage put out by the KS increases with Knock....
.. So my thinking is what about hooking up a volt meter gauge to the KS harness.. you could then watch the gauge and if it starts increasing it would give you pre warning of issues.. like if you get loss of power.. and no clue why just glance at the gauge and see what its up too
Old Apr 28, 2005 | 03:54 PM
Kevlo911's Avatar
Kevlo for President
You can do that...
Old Apr 28, 2005 | 04:04 PM
The manual didn't mention the actual voltages, I guess I have to see if its going to be high enough to measure with your average voltmeter gauge
Old Apr 28, 2005 | 04:08 PM
VeN0m's Avatar
voltage? I thought it was a change in resistance?
Old Apr 28, 2005 | 04:54 PM
Loe max's Avatar
ohm
10char
Old Apr 28, 2005 | 07:05 PM
Ninos_Maxima's Avatar
be the change u want2C
so your measuring while its on, and then if the ohms go up you got a problem?
Old Apr 28, 2005 | 07:33 PM
AxisKill's Avatar
i believe it's supposed to be 500ohm .. said something like that on FAQ.. ill check
Yeah thats the one, I'll check my manual later but pretty sure it said volts
Old Apr 28, 2005 | 07:34 PM
AxisKill's Avatar
yea about that .. :
"A good KS will measure ~550 k-Ohm resistance between the left pin of the KS and ground. You can check the resistance without removing the KS by following the harness to the connector. The connector has two pins, only one of them hooks up to the KS, so try them both. "
http://forums.maxima.org/showthread.php?t=254238
Old Apr 28, 2005 | 07:37 PM
You sure you guys aren't thinking of Drop Resistor which is about 400-700ohms
OR the Hack you can do to fool the ECU is to put a 470k resistor instead of the KS but I still think it said it was voltage governed..
I think the OHMs reference above is just for testing purposes.. as in testing the internal component to make sure theres continuity not neccessarily its operation.
Once I find out either way, I guess the next thing would be to hook up a multimeter measure the KS output and determine if I can purchase a gauge that is capable of measuring the flutuations.
Old Apr 28, 2005 | 10:08 PM
Maximeltman's Avatar
i think if the ohms went down you have a problem. voltage would have to raise, but not sure. if the resistance went up, like infinite, then you definately have a problem(bad ks).
litch
123
Jan 4, 2024 07:01 PM
MichMaxFan
Sep 30, 2015 09:18 AM
Marc2theMax
Sep 28, 2015 08:13 AM
Socalstillen
Sep 26, 2015 12:01 PM
