KS + Voltmeter = Early Warning System?
I was reading my Haynes manual like a good maxima/cefiro owner should and it says that the voltage put out by the KS increases with Knock....
.. So my thinking is what about hooking up a volt meter gauge to the KS harness.. you could then watch the gauge and if it starts increasing it would give you pre warning of issues.. like if you get loss of power.. and no clue why just glance at the gauge and see what its up too
yea about that .. :
"A good KS will measure ~550 k-Ohm resistance between the left pin of the KS and ground. You can check the resistance without removing the KS by following the harness to the connector. The connector has two pins, only one of them hooks up to the KS, so try them both. "
http://forums.maxima.org/showthread.php?t=254238
Originally Posted by AxisKill
i believe it's supposed to be 500ohm .. said something like that on FAQ.. ill check
OR the Hack you can do to fool the ECU is to put a 470k resistor instead of the KS but I still think it said it was voltage governed..
I think the OHMs reference above is just for testing purposes.. as in testing the internal component to make sure theres continuity not neccessarily its operation.
Once I find out either way, I guess the next thing would be to hook up a multimeter measure the KS output and determine if I can purchase a gauge that is capable of measuring the flutuations.
Originally Posted by Ninos_Maxima
so your measuring while its on, and then if the ohms go up you got a problem?
litch
123
01-04-2024 07:01 PM
