oil pan spacer
Old May 4, 2005 | 08:43 PM
choray911's Avatar
The Crazy Azz Cracka
oil pan spacer
Has anyone tried the jwt oil pan spacer that adds a quart of oil. Will it even fit the vq35 maxima pan. I know there isn't any luck for the vq30, but one can wish.
Old May 5, 2005 | 06:39 AM
stephenlc's Avatar
haha i think it will sit really low on the FWD VQ.
Old May 5, 2005 | 10:47 AM
choray911's Avatar
Only an inch or so. My down pipe sits lower than that.
Old Aug 22, 2005 | 02:15 AM
madmxx's Avatar
sorry to dig up an old thread, but i am curious about the same thing and it looks like no one really answered the question...
will the oil span spacer for the 350z/g35 fit the 3.5L max? my car has a serious oil burning problem so i am interested in this spacer so i dont have to check/refill my oil so damn much
Old Aug 22, 2005 | 05:35 AM
Stephen Max's Avatar
Sorry I can't answer your question.
Doesn't Nissan have an engine replacment policy concerning engines that are consuming too much oil? If you can get a new engine, that would be much better than increasing oil capacity.
Old Aug 22, 2005 | 09:04 AM
Fred Allen Burge's Avatar
I'm using a Z's 3.5L oil pan (upper and lower) on my VQ30 (swapping into a 240sx) so the pan will bolt up just fine and I assume then that the spacer would bolt up fine but I haven't tried it. The added depth may affect your crossmember clearance though, not sure.
The Z's lower pan is nearly identical to the VQ30's. Drain plug location was different if I remember correctly.
allen
Old Aug 22, 2005 | 10:27 AM
choray911's Avatar
Yeah this post should not have been revived! The spacer will bolt up no prob but if ur max is lowered you will not make it in to a Wendy's parking lot with out ripping out the lower steel pan. Plus it lowers the pan so much what there isn't much clearance between the y pipe and lower pan, making the oil temps much higher. Its possible but not probable.
In your case it would only add oil below your pick up making the mod useless unless you extend the pickup tube dramaticly.
Choray
litch
123
Jan 4, 2024 07:01 PM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
