my boy has a s-tech and agx drop for a month now and its still is high, whats wrong?
my boy bought some s techs from southwest autoworks and installed it about a month and a half ago, it still looks stock, well my eibach drop is lower then it. what could be wrong? i know its not h -tech becasue it is green, and the box said s-tech.
neone know what the problem could be? an proffesional mechanic installed it
Some springs just sit differently. I have eibachs and so does a friend of mine and his sat lower than mine, maybe b/c he had subs and full trim trunk and I didn't have anything in mine, no carpet/spare etc.
check it out http://www.maximafreak.com/stereo/im...G_2162_JPG.gif
thats stech and his and manual maximas look much higher
Dude i have s-techs and its low as heck. I also have an manual if that has anything to do with it. pics are at www.cardomain.com/id/97whtse
it does look pretty low, but the kit helps also. what's with the phone on the front lip? is some new aerodynamic mod? looks great!
2 da max, did you do a before and after measurement? you did start off pretty high up in the air, so even a large drop will only get it down to where it should be. The roof of a stock max is so high up in the clouds, that it should have been the car called the SKYLINE! woo!! bad joke of the month! (does this mean i get a free digital camera?)
yea i know someone who has them and their caris slammed and mine just sits up there. i dunno what is wrong with them, but as said above they are installed properly. coil overs are comming this summer so i am not sweating it to much.
My next setup is AGX on S techs as well. Maybe the struts weren't put together correctly.
I have no idea. 2.2" front/1.8"rear drop is a pretty big drop to not see the difference. Something is definitely wrong. If I was him, I'd take the struts off and make sure that the springs are seated right & strut mounts up against the tower all the way. If he doesn't want to do the work, take it to another shop that knows what they are doing. At any rate, his car should be sitting LOW.
I uno that's wierd, but that girl...she can get it. No disrespect tho if that happens to be ya girl, but yeah lol.[/QUOTE]
???? get what..i dun get it......anyways, y would anyone get reg springs n shocks if you're worried about the height that much. You know that every spring is gonna sit different n now adjust to the height you want. But maybe its because of your strut..-= ) anyone else think about that??? Are you using your stock ones? if so, then that might be you're problem. running aftermarket springs on stock strut = bad news. You're gonna blow your shocks and eventually gonna have to buy new ones.
struts just determines how harsh or soft the ride is
2 finger gap makes sense, i have a very tight 3 finger gap on tokico's (~1.5" final lowering)
if your "boy" doesnt have a 2 finger gap, take the front suspension apart and do it again, ive seen situations where the top mount wasnt put in correctly (backwards?) and was not sitting flush against the chassis, thus, the front sat kinda higher.
is it an even drop all around? if so, could be factory mistake/defect
Hey 2 Da Max, how does the ride look with just the lip? I was thinking of doing the same thing but im afraid it wont look right. Specificly i was concerned that i might get a "snowplow" look lol. My car isnt lowered and i got SE rims.
sdotcarter
Sep 2, 2015 09:53 PM
Justin Kroll
Sep 2, 2015 11:06 AM
