Deglazing the front pads
Old May 25, 2005 | 07:46 PM
MaximaGuy719's Avatar
Does this work? I was recommended to do this to stop front brake pad squealing. Do I just take the pads out and grit them with sand paper or against the concrete? Do I do this to the front side, the side that touches the rotor?
Any help would be cool.
Old May 25, 2005 | 08:11 PM
ChrisCheezer's Avatar
i wouldnt do it against the concrete!
but I would use some emery cloth to clean the pads up, and get some glazing off i would also get some good brake grease and grease all the moving/sliding parts on the caliper.
Old May 25, 2005 | 08:40 PM
So I sand paper the front side of the pads?
Old May 25, 2005 | 08:55 PM
Drivin Maxima's Avatar
Yeah take some medium grit sand paper and hit the friction side of the pad (in other words the side that contacts the rotor). that should take care of the glazing. Good luck
Old May 25, 2005 | 08:56 PM
Thanks a whole lot
Old May 25, 2005 | 09:12 PM
Jim_1990SE's Avatar
Depending on the given circumstances, this may not be the solution to the problem.
Variables include:
- How long the pads have been on there already.
- When the squealing happens:
- Brakes are cold / hot
- Noise happens whether the brakes are being applied or not
- Only during harder braking
- Are they asbestos pads ? or Semi-metalic ?
Extra thoughts can't hurt.
-Jim
Old May 26, 2005 | 02:13 PM
Kikcaffine's Avatar
Put the car in reverse, get going to around 15 miles an hour, and get on the brakes decently hard. It will reverse the glazing, and boom, no more squeaking pads. Unless they just need to be replaced, then get hawks.
wyobbagy
Jan 3, 2023 12:03 PM
bbsitum
Sep 11, 2015 04:55 PM
Hdnseek
Sep 9, 2015 05:55 AM
jfl330
Sep 4, 2015 01:44 PM
A32goldylocks
Sep 2, 2015 06:39 AM
