Stupid DDE's Ballast
Ok just blew the passenger side ballast for my DDE's angel eyes, i remember a thread about a different ballast, AND I DID SEARCH FOR IT GUYS, but it must have been titled something else, well anyway, do you thick i should call up the manufacturer and get a replacement or do something different? lemme know homies
http://www.itcelectronics.com/
it was from those guys, you needed one ballast per ring...just cant remember which one...sorry
supposedly it makes the rings brighter too, so you may think about buyin four, that way all the rings are equally bright and if one goes you only have to replace one at a time in the future...
its not a ballast it is a inverter, 2 different things....
google CCFL & inverter and you will find many cheap replacements, you can probably find a inverter w/ a 12V input to fire both rings for around $5. if you do a decent search
This is what you need to do. I've had tons of these go out until i figured out that water was getting into them. Seal them as soon as you get it with silicone but i found it best to use waterproof shower caulk from home depot. after i did that i havent had a "ballast" blow since then and that was over a year ago.
03VQMAX
Nov 10, 2015 03:39 PM
alphakaoz
Sep 30, 2015 07:33 PM
pears
Sep 18, 2015 05:25 AM
Maxima30
Sep 7, 2015 06:13 PM
