4th gen SC on a 3.5?
JC gave me this idea... he mentioned install the 4th gen timing chains then the SC..
I just want some feed back on this and what to look for, basicly your 02.. there are quite a few heads looking for a boost option and this might be one if I can get some info from the guys that have them or have knowledge of the swap...
so, is it possible or not is my Q?
and your 02 on what to do would be appreciated....
EDIT: is the SC to small for the 3.5 engine? you think it would "full spool" to early and leave little boost for high end......... I'm lost please help..
thanx, TEK......
thanx, TEK......
Originally Posted by IceY2K1
It would work, most likely, however you'd have to eliminate the CVTC which would mean a CEL at the LEAST.
The V2 can support ~400whp.
it would work with our 3.5 timing chain or the 4th gen one?
and what the hell is a CVTC?
No, I can't break it down, since it has never been done. However, the theory is just like VQ35s into 4th gen swaps. Basically, remove the VQ35 timing cover, VTC pulleys, and replace with VQ30 sprockets, JWT sprocket adapters, and the VQ30 timing cover...then bolt on the SC like any VQ30 would. You'll need to massage the intake piping a bit to work with the 5.5gen throttle body placement, but probably not much.
yea I figured the pipes will have to be custom fitted.. but if it will work with the sprockets and all the pulleys I will look into it..
I need to find me a mech that knows about this **** to help me...
thanx.....
thanx.....
Originally Posted by Tek-Niq
cause NY and PA are too far for me ICE.........
How about Paul@Avalon Racing?
6 Jason Drive
Londonderry, NH 03053
6 Jason Drive
now that I think about it, isn't there a place across the way from CE in danbury CT? cause NY and PA are too far for me ICE.........
Originally Posted by DA-MAX
hell, if you are really serious than the drive to PA would be nothing...Tilley knows his **** about the 3.5s, I bet if you got all the parts for him he could whip it together given some time
thanx ICE, I will send him a e-mail..
6 Jason Drive
6 Jason Drive
really... is he on the org by any chance.... I can talk to him and possibly start getting all the parts that I need....
he's practically the 4th gen/3.5 swap king.... s/n is Tilleys99, his shop is in PA near Hershey. he's probably done more 3.5 swaps than anyone on here
Originally Posted by NmexMAX
It needs to be tuned for proper fuel requirements.
SC = more air = more fuel.
You will have a check engine light due to the IVT(intake valve timing) control not being able to rotate the intake cam once you replace the VTC pulleys with the VQ30 timing sprockets. However, from what I can tell from the FSM, the ECU shouldn't kill the fun with the fuel-cut countermeasures. IIRC, people have had IVT codes without having the ECU failsafe mode limit RPM under 3000rpm or whatever.
good thinking....... I pm'ed tilley already so hopefully he gives me a parts list so I can go hunting....
thanx guys.. now I have to get to work here and find a mechanic and have tilley's help on the side...
keep the comments coming I need all the help I can get.....
that light would suck, I just don't whant something to happen and not be able to tell cause the light is on all the time...
hopefully we can find a way to have it off and working properly..
Originally Posted by chris'smax
what about the oil drain back plate and the belt adjuster bracket? Are the placements and fittments the same as the 3.0?
Those are all attached to the timing cover, correct?
Human error would keep it from being balanced and straight. The only way another pully could be added to the crank would be to machine it out of aluminium, or to have it cast in steel. Both of those options with buying a used charger would be more expensive than buying a new unit from stillen. Welding new brackets for the SC would be much more practical if one was to posess the skills.
Choray
Choray
MAXSE5SPD
Sep 17, 2022 04:00 AM
Violator
Sep 9, 2015 10:14 AM
