4th gen SC on a 3.5?
Old May 31, 2005 | 04:09 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
JC gave me this idea... he mentioned install the 4th gen timing chains then the SC..
I just want some feed back on this and what to look for, basicly your 02.. there are quite a few heads looking for a boost option and this might be one if I can get some info from the guys that have them or have knowledge of the swap...
so, is it possible or not is my Q?
and your 02 on what to do would be appreciated....
EDIT: is the SC to small for the 3.5 engine? you think it would "full spool" to early and leave little boost for high end......... I'm lost please help..
thanx, TEK......
Old May 31, 2005 | 04:27 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
It would work, most likely, however you'd have to eliminate the CVTC which would mean a CEL at the LEAST.
The V2 can support ~400whp.
Old May 31, 2005 | 04:28 PM
IceY2K1's Avatar
Oh yeah, the VQ35s torque with the V2 SCs top-end would be a PERFECT match IMHO.
Old May 31, 2005 | 04:38 PM
Tek-Niq's Avatar
can you break it down for me..
it would work with our 3.5 timing chain or the 4th gen one?
and what the hell is a CVTC?
Old May 31, 2005 | 04:42 PM
IceY2K1's Avatar
No, I can't break it down, since it has never been done. However, the theory is just like VQ35s into 4th gen swaps. Basically, remove the VQ35 timing cover, VTC pulleys, and replace with VQ30 sprockets, JWT sprocket adapters, and the VQ30 timing cover...then bolt on the SC like any VQ30 would. You'll need to massage the intake piping a bit to work with the 5.5gen throttle body placement, but probably not much.
Old May 31, 2005 | 04:56 PM
Tek-Niq's Avatar
yea I figured the pipes will have to be custom fitted.. but if it will work with the sprockets and all the pulleys I will look into it..
I need to find me a mech that knows about this **** to help me...
thanx.....
Old Jun 1, 2005 | 09:48 AM
IceY2K1's Avatar
There's MaxTuning in NY or Tilley in PA that could probably easily do it.
Old Jun 1, 2005 | 12:48 PM
Tek-Niq's Avatar
now that I think about it, isn't there a place across the way from CE in danbury CT? cause NY and PA are too far for me ICE.........
Old Jun 1, 2005 | 01:06 PM
JClaw's Avatar
What, you're buying a 4th gen?
Old Jun 1, 2005 | 01:11 PM
Tek-Niq's Avatar
no, just the SC to put on my 6th gen.....HAHAHA
Old Jun 1, 2005 | 01:17 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
hell, if you are really serious than the drive to PA would be nothing...Tilley knows his **** about the 3.5s, I bet if you got all the parts for him he could whip it together given some time
Old Jun 1, 2005 | 01:19 PM
IceY2K1's Avatar
How about Paul@Avalon Racing?
6 Jason Drive
Londonderry, NH 03053
Old Jun 1, 2005 | 01:20 PM
Tek-Niq's Avatar
really... is he on the org by any chance.... I can talk to him and possibly start getting all the parts that I need....
thanx ICE, I will send him a e-mail..
6 Jason Drive
Old Jun 1, 2005 | 01:24 PM
DA-MAX's Avatar
he's practically the 4th gen/3.5 swap king.... s/n is Tilleys99, his shop is in PA near Hershey. he's probably done more 3.5 swaps than anyone on here
Old Jun 1, 2005 | 01:27 PM
Tek-Niq's Avatar
thanx DA-MAX........ wow this looks doable I can't wait..............
Old Jun 1, 2005 | 01:29 PM
DA-MAX's Avatar
good luck man, a SC'd 6th gen would be nice
Old Jun 1, 2005 | 02:06 PM
NmexMAX's Avatar
dot dot dot ...
I think you'll have more electronic/software issues than mechanical fitment issues.
Old Jun 1, 2005 | 02:21 PM
Tek-Niq's Avatar
electronicly.... what would have to be done?
Old Jun 1, 2005 | 02:29 PM
NmexMAX's Avatar
dot dot dot ...
It needs to be tuned for proper fuel requirements.
SC = more air = more fuel.
Old Jun 1, 2005 | 02:32 PM
Tek-Niq's Avatar
ah, I don't wanna say "JET" chip, but where can I prog the ecu to those specs that's not JET..
Old Jun 1, 2005 | 02:37 PM
NmexMAX's Avatar
dot dot dot ...
Can't help you with that. I'm an N/A guy ...
But the kits from Stillen typically come with their own fuel management system ...
Now I'm only a spectator ..
Old Jun 1, 2005 | 02:44 PM
IceY2K1's Avatar
You'd just use either an eManage or Split Second piggy-back like Vortech and Greddy use on their SC/TC kits.
Old Jun 1, 2005 | 02:51 PM
IceY2K1's Avatar
You will have a check engine light due to the IVT(intake valve timing) control not being able to rotate the intake cam once you replace the VTC pulleys with the VQ30 timing sprockets. However, from what I can tell from the FSM, the ECU shouldn't kill the fun with the fuel-cut countermeasures. IIRC, people have had IVT codes without having the ECU failsafe mode limit RPM under 3000rpm or whatever.
Old Jun 1, 2005 | 02:53 PM
Tek-Niq's Avatar
good thinking....... I pm'ed tilley already so hopefully he gives me a parts list so I can go hunting....
thanx guys.. now I have to get to work here and find a mechanic and have tilley's help on the side...
keep the comments coming I need all the help I can get.....
Old Jun 1, 2005 | 03:00 PM
Tek-Niq's Avatar
that light would suck, I just don't whant something to happen and not be able to tell cause the light is on all the time...
hopefully we can find a way to have it off and working properly..
Old Jun 1, 2005 | 04:55 PM
chris'smax's Avatar
what about the oil drain back plate and the belt adjuster bracket? Are the placements and fittments the same as the 3.0?
Old Jun 2, 2005 | 06:36 AM
viguera's Avatar
I have no clue where those are, but if you tell me where they should be, I can jack my car up and look for them, and take some pictures.
Old Jun 2, 2005 | 06:53 AM
chris'smax's Avatar
look at the supercharger install directions in the stickies and they have a diagram of everything bolted up
Old Jun 2, 2005 | 09:12 AM
IceY2K1's Avatar
Those are all attached to the timing cover, correct?
Old Jun 2, 2005 | 10:03 AM
chris'smax's Avatar
from what i remember the oil drain back is, but not the belt adjuster bracket(someone correct me if i am wrong.
Old Jun 14, 2005 | 03:36 PM
socalsean
Instead of running the timing gears from the older engine and dealing with the cam gear issues, why not weld another pulley to the crank pulley and use it to drive the supercharger?
sean
Old Jun 14, 2005 | 09:21 PM
choray911's Avatar
The Crazy Azz Cracka
Human error would keep it from being balanced and straight. The only way another pully could be added to the crank would be to machine it out of aluminium, or to have it cast in steel. Both of those options with buying a used charger would be more expensive than buying a new unit from stillen. Welding new brackets for the SC would be much more practical if one was to posess the skills.
Choray
MAXSE5SPD
Sep 17, 2022 04:00 AM
220k+ A32
Sep 11, 2015 02:18 AM
I<3 A32's
Sep 10, 2015 11:07 AM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
