Do your fog lights go out with high beams on?
Just happened to notice this when I had my high beams on so that I could get out of the car to see something outside the house. My stuff has been pulled apart before, though, when I had a short that kept blowing the fuse to my instrument cluster lights and the tails. Just making sure they didn't put something back together wrong.
Yes, it is supposed to do that. Some people re-wire. I don't see the point of re-wiring. All you need to so is move your high-beam steering staulk into the middle postion and both work fine.
Originally Posted by queenambeach
Boy did I think the same thing but I was so WRONG!! You still need your highs man.
if your fogs are factory or are wired into the factory harness they will go out when you put your highbeams on there is a mod in the 4th gen mods forum that i believe shows you how to tap into the wires so that lour fogs will always stay on. if you have aftermarket fogs and have them wired to a switch that you installed it depends on how you wired your fogs.
Justin Kroll
Sep 2, 2015 11:06 AM
umnitza
Sep 1, 2015 01:03 PM
