A REALLY annoying noise!!!! Its driving me nuts!! Help!
hey guys, yesterday my radio started acting funny
it makes a high pitched noise when the car is moving and not as much when stopped, it just started doing this and i didn't touch the system at all it has been the same way for 4 months and this problem just started. The noise gets higher in pitch as the revs go up, it sounds like a really high whistle and its not a vaccuum leak because the noise is not present when the stereo is off. If anybody could tell me where to begin or just adivice that would be great.
~Clean
it makes a high pitched noise when the car is moving and not as much when stopped, it just started doing this and i didn't touch the system at all it has been the same way for 4 months and this problem just started. The noise gets higher in pitch as the revs go up, it sounds like a really high whistle and its not a vaccuum leak because the noise is not present when the stereo is off. If anybody could tell me where to begin or just adivice that would be great.~Clean
If you are running an after market amp then it may be the ground on the amp or just the quality of the amp. Unfortunatly this problem happens alot with the factory BOSE systems. Each speaker has its own amp built in to the speaker, meaning that there is an amp in each door. When they get some dirt and moisture on the circiut they start makimng ungodly noises. Highpitch squeels, scratchy sounds, intermittent sound, and low end thuds. If it is the factory system the only way to fix it is to replace all 4 speakers and the radio. It's not cheap.
Choray
Choray
I have the same thing happening after I put in my amp/sub. But I'm fairly sure its my ground (gotta try to find a good one) and I'm putting a noise suppressor on my alt. BTW, does anybody know where a good ground is located in the trunk?
Originally Posted by CleanMAX98
my a/c only works on 4 lol i just found this out today, and ideas with this new problem
there is always somthing
if you need more info then i can take pics from mine & guide you through it.
thanks a ton, im gonna do that tomorrow
take that off the list of things to do:
-knock sensor
-figure out the radio whine
-new brakes
-new rotors
-alignment
-install my drop
-get new tires
-fix dome light
-fix a/c
- new bumpstops
-new plugs
-clean coils
my god the list keeps growing and growing, i might sell it
-knock sensor
-new brakes
-new rotors
-alignment
-install my drop
-get new tires
-fix dome light
-fix a/c
- new bumpstops
-new plugs
-clean coils
lowpost99
Oct 26, 2025 06:53 PM
Maxima30
Sep 7, 2015 06:13 PM
