0302 how do you fix it plz help
http://forums.maxima.org/showthread.php?t=90535
http://forums.maxima.org/showthread.php?t=403116
To summarize: I would recommend cleaning out the EGR port on the back of the upper intake manifold (also called the plenum). This is not an easy job and it maybe worthwhile to have the dealer do the work. Local dealers quoted me around 200 dollars to pull and clean out the EGR passageways.
Cheers.
Cheers.
Originally Posted by 97MaximaSE
just dont fix it like i did...i replaced almost everything pertaining to this code and still havent solved it so if you do let me know
yup changed the soleniod, checked function of the egr valve and cleaned out the passages...still have that fun 0302 code......luckly it doesnt really affect driveability so it doesnt bother me so much anymore....i always throw the 0707 code cause of my gforce ecu anyway
im telling you if you wanna try some coil packs this weekend let me know...i have a bunch lying around and you live about 10 min away
this also depends on wether or not i get my car back since my pcv grommet fell into my engine and the new one takes 2 days to come in.....also i broke another wire in my harness and need to resplice and make it longer
i had a friend and i tried his coil packs that work great and that didnt help : ( Im dropping off my car to the guy who put my engine in. Ill let you know what he says. Unless you want to help me take the intake manifold off
Originally Posted by DcMaN
i also have this problem except my car runs like **** my idle is very vicious it shakes my car real bad i have almost no power on accerlation and i have a huge amount of hesitation.
Thats not related to 0302...I have that and my car runs perfectly.
Well I'll be damned. You're not gonna believe it but there is a link in the HOW TO that shows what to check and how to check it. Your lazy *** should be banned.
http://forums.maxima.org/showpost.ph...86&postcount=5
i think the only reason i havent been able to remove the code yet is because i have a short or a wire break in the harness pertaining to the soleniod. when hooked up to the consult it shows the soleniods never stays open for more than a split second like its being shorted out
Vacuum leak?
i brought mine to the guy who put my engine in today does your car idle terrible ? If so the egr valve seems to stuck open. He still has my old motor so hes using it from my old motor and putting it on the newer one
and you still have the code?
