About stereo not working...I need help big time
Okay, My Cd player in my car was working fine and then it stopped. It is not getting any power but all the wires are hooked up right and everything. What could it be it wont even come on now.
If you have a Multi Meter ensure you are getting voltage to the harness right as it enters the HU. Also ensure you ground is secure. Make sure if it is an aftermarket HU the ground is tied directly to the chassis.
get a multimeter.
then find out if it's getting power.
if it's not check where the wire gets power from and keep tracing it back through fuses etc...
Check your ground as well...
if it is getting power + a good ground and it still doesn't turn on go and get it looked at, repaired, or buy a new one....
you said you checked the fuse....which one?
your multimeter will tell all.
trasmadean
Feb 1, 2017 08:20 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
