Engine vin #?
Old Jun 15, 2005 | 08:13 AM
Seximus Maximus's Avatar
Engine vin #?
Where is the VIN# located at on the engine? I am trying to confirm the year engine that was put in my car. They said it was a '98 but im just making double sure.
Old Jun 15, 2005 | 08:21 AM
Bobo's Avatar
It is on a plate on the dashboard. You can read it from the driver's side if you look in the window. I believe its also located inside the driver's door on the right, at least it is on mine. It is also on your bill of sale. Is it on your car insurance?
Why would a 99 Maxima require an engine replacement?
Edit - Half asleep. Now I see where you're coming from. Good luck!
Old Jun 15, 2005 | 08:26 AM
NmexMAX's Avatar
dot dot dot ...
95-99 are all the same engine, rated hp, etc ... the engine code is on the block just under the intake manifold located in the front left (driver side) and reads VQ30DE, but this is the same for all Maxima year models 1995-1999. There's now way you can relate a VIN to an engine unless the company that sold you the egine told you what car it came from with VIN# ,,,
Old Jun 15, 2005 | 08:28 AM
njmodi's Avatar
Do I get a tax break?
rmurdoch - I think he had a replacement engine put in - so he wants to know where the VIN is on the block itself - to make sure it came from a 98. He doesn't want the VIN that is on the car body.
I can't tell exactly, but there are two VIN numbers inside the engine bay near the firewall (right under the cowl). Not sure if either of these are "on the engine" or on the car body. There is an engine serial number on the engine right near where the transmission is bolted to the engine. It is located under the TB on the block. Not sure if its visible from above with all that EGR, vaccum stuff in the way.
Old Jun 15, 2005 | 08:34 AM
Bobo's Avatar
I figured that out immediately after I submitted my reply. It strikes me he should have ascertained the engine particulars before he ever bought the car. The engine in all likelihood has more miles on it than the one it replaced.
Old Jun 15, 2005 | 08:47 AM
I did research the engine i had put in. I had the engine replaced with an engine from a '98 but im just making TRIPLE sure that it is a '98 engine. Call it to ease my mind w/e.
Old Jun 15, 2005 | 08:50 AM
Bobo's Avatar
Back to my earlier question, why did the engine need to be replaced in the first place and at what mileage? Lastly, how many miles did they say were on the 98 engine?
The mileage on the installed engine is what is important, it could be a high mileage 98 or a lower mileage 95, what is important is the mileage, not necessarily the year!
Old Jun 15, 2005 | 08:52 AM
NmexMAX's Avatar
dot dot dot ...
There's no way to check the VIN from the engine itself unless you got the VIN of the car it was donated from...
Old Jun 15, 2005 | 08:55 AM
MaximaSE96's Avatar
Maxima Owner
the engine has no VIN because the engine is not a VEHICLE....the only thing on our motors is the engine code....there might be a tag somewhere with teh production date but i dunno where it would be..call a dealer and ask
Old Jun 15, 2005 | 09:03 AM
thank you very much for the posts. i appreciate it.
The engine was replaced due to a minor oil issue >.> The engine new engine has 37k on it
Old Jun 15, 2005 | 09:08 AM
Bobo's Avatar
Then don't sweat the small stuff and get on with life!
Old Jun 15, 2005 | 09:11 AM
sdoherty_tjm's Avatar
bull**** minor oil prob, you wouldnt replace it, and nice pick up for the 37k
Old Jun 15, 2005 | 09:29 AM
it was minor! i swear!! hahahaha
Old Jun 15, 2005 | 09:34 AM
wikidminds's Avatar
com on now u ca ntell us what rrreeeaaaaaaalllllyyy happened to ur engine. we wont laugh.
but on a real note...what really did possess u to change ur motor?
Old Jun 15, 2005 | 09:36 AM
NmexMAX's Avatar
dot dot dot ...
It's your money not mine, and a minor oil problem shouldn't need an entire engine replacement, spend it how you choose.
And how do you know it has 37k?
minor =
Old Jun 15, 2005 | 09:58 AM
Come on now guys. I was being sarcastic. My oil leaked out on the way to work and ~poof~ siezed engine. I went and checked the car it was pulled from when i got the engine. But nowadays you really never know with anything you buy regardless. My reasoning for asking was im buying a SC and if for some reason god only knows it turned out to be some crazy year engine and problems arose after i spent mad cash + drove hours to a mechanic, i would not be happy. Just trying to cover all my bases ya know?
Sorry if you think this thread sux.I was just trying to figure some things out. You can delete it if you would like.
Old Jun 15, 2005 | 10:06 AM
Bobo's Avatar
So now you say you previously checked the car out that the engine came from. What year was it, a 98 I presume. Hence, this thread is pointless.
Old Jun 15, 2005 | 10:21 AM
Nealoc187's Avatar
SLOW
I don't know of anywhere the engine has the VIN stamped on it, but the VIN is stamped on transmissions, so the theory about the part not being a "vehicle" thus not having a VIN is incorrect.
I think this thread is just fine btw. Like if you just got the engine from a boneyard, they tell you what year it is but you don't have any way of really knowing. Also there are minor differences, such as a 99 cali spec with swirl valves, or a 96 I30 has a small emissions difference, etc. 99s also require a different supercharger kit than the 95-98s (though I think it's just a different bracket.
Old Jun 15, 2005 | 10:25 AM
NmexMAX's Avatar
dot dot dot ...
Some yards also have small quirks to them. Say the have a certain amount of 4th gens, with engines ranging from 37k miles - 189k, and you get somewhere in between that because they, at times, don't tell you which one you got, but only provide a range.
Old Jun 15, 2005 | 10:29 AM
nmex you must live here seriously
Old Jun 15, 2005 | 10:34 AM
Bobo's Avatar
How recently did you get this engine? Perhaps the car it was pulled from (you know the one you previously saw) is still at the autowrecker and you can go back there and determine the year of the vehicle, read the odometer, take pictures of it, have a seance and come away with a warm and fuzzy feeling!
Old Jun 15, 2005 | 10:43 AM
They dont have the vehicle anymore. I know it was a '98 max at the yard so its supposed to be a '98 engine. but whats to say the engine in it WAS a '98? cause i couldnt tell. Anyway problem solved. thx all
Old Jun 15, 2005 | 10:47 AM
NmexMAX's Avatar
dot dot dot ...
Yup..
i'm a lifer/permy ...
Old Jun 15, 2005 | 10:50 AM
lol i sit here all day and f around while at work i joined monday or friday or somethin'
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
