Just failed smog check
The CO and NO is fine, but the HC is a little bit more than allowed. Max allowed is 54 at 15mph test and 37 at 25mph test, I have 58 and 49. My car has a cold air intake and a Y pipe. Does anyone have similar problem and how do you get your car pass the smog check?
Originally Posted by rmurdoch
How far did you drive and at what speed and how long was the engine on before you were tested?
I say drive on the freeway at least 10-15 minutes or in town 20 minutes. That'll get it nice and warmed up. You don't need to go pedal to the metal. Just get it warmed up. I thought everyone knew to get their car warmed up properly before testing emissions. Hmm...
Let us know how it turns out tomorrow.....thanks...
Originally Posted by masterB
drove about 2 miles and sitting with the engine on for 5 mins. I guess that isn't enough. I will drive at least 5 miles and do some pedal to the metal driving before the test again tomorrow
When was the last time you changed your spark plugs, air filter, oil & filter?
hehe I know I know ... It started out ok ... But it's in the stickys, and I'm trying to be nice today .. Also, he hasn't chimed in so either he took his car in cold or there;s something else wrong ... But at it;s CURRENT state
I'm f***ed!! I went to do the smog check after the car warmed up completly, and I still failed the god damn smog check. I need ideas what I need to fix to pass the smog check. My worst case is borrow a stock y pipe from someone to pass the test but I really don't want to do that. HELP ME PLEASE.
What were your readings relative to the first failed test? Do you still have your stock air box? What make of y-pipe do you have? What did you do with your OEM y-pipe? They are quite expensive and you should have hung on to it.
Also what year is your car and how many miles are on it?
JoshG
51
Sep 21, 2015 10:41 PM
DayHeyZeus
Sep 11, 2015 03:17 PM
sdotcarter
Sep 2, 2015 09:53 PM
