Cracked Oil Return Line on V2
I just discovered this yesterday after wondering why I was getting an oil leak after reinstalling the blower. I have a split right where the upper hose clamp grips the outlet nozzle under the blower. Would a rubber hose of the same size be good enough as a replacement?
Just get a stock 4th gen crank case breather hose. To my knowledge this is the exact one stillen used in the kit. I cut mine when taking the blower off a few months ago and used one of my buddies hoses he had just laying around. You have to use a hose w/ that exact bend because every other configuration i tried that wasn't perfect got a kink in it.
Thanks again Spiggy
Thanks again Spiggy
I don't believe it! I've checked with a dealer and they don't have it in stock. Then they checked with the Nissan Canada warehouse and they have none in stock either. An estimated 3 weeks if I put an order in. I'll have to check with ebay or else the nissan links in the group deal forum for a better solution.
When you Recieve this hose, it is to long to work for the blower...it will need to be cut just alittle bit so it doesnt kink...put it on, match it to the car, cut alittle bit, put it back up the car, and keep doing that till the Kink comes out
Originally Posted by matty
Call up David Burnette before you go to Ebay 1888 254-6060
Update: Got the fiche and its part #11823, cost $28.00Cdn out of Toronto.
Thats where everyone replaces the hose with the crankcase breather filter. Anyways, it'll come in next Tuesday.
Thanks very much for the offer but I've found the original crankcase hose!
I had remembered that the kit had come with the hose already and I checked my parts box where I saved the air box and other parts.
Update: Yes, it fits perfect!
James92SE
142
Jan 2, 2024 09:23 AM
foodmanry
Sep 24, 2015 12:02 PM
97_GXE
20
Sep 17, 2015 08:12 PM
