Finally Fixed my car
Old Jun 25, 2005 | 04:21 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
My old sn is seximagtr, so if you recall, I had problems and I couldn't boost correctly because of what i thought was a wastegate or boost controller problem. I found out that the rubber gasket between the upper and lower plenum was popped out... So i tightened that, set the boost to 12 lbs - as that was what the car was tune for previously.
I forgot that I had turned the gain to 80 in an effort to get it to spool...
I hit 16.8 psi, with my eye on the wideband the whole time... A/F never went above 12.5 on the DOT. Jesus christ that was scary. It's good to have the car back
Lakersallday24
Nov 7, 2024 07:31 PM
Lakersallday24
Jun 16, 2019 01:35 AM
JMag90
Aug 25, 2015 09:17 AM
maxinout93
Aug 16, 2015 07:25 PM
kirkhilles
Aug 8, 2015 10:53 AM
