how to aim fogs in a 2k
There is a white adjustment screw at the bottom of the back side. You will have to remove a couple of screws and clips to bend the front of the inner fenderwell enough to reach it from underneath. To reach it from above remove your headlight but it is hard to see. You will have to do it by feel.
You can only adjust up and down with the adjustment screw.
Recently I installed the yellow capsules and noticed that light was brighter... I think it is mostly due to the fact that the installation requires permanent removal of the light guards which limit the light coming out. So you can may be think about just opening the lens and removing the "guard"...
i removed my guards, but havent had a chance to test ou the lights yet, cars at the dealership right now, but they looked 3x brighter than they did with the guards in, but then agaqin my bulbs are much longer than a standard h3.
Originally Posted by Lontar1
and still you wont see crap with them, unless you get HID's for the fogs...... ours Fogs SUCKs
If you are interested in what I did on the cheap the writeup is Here
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Calabar
Oct 5, 2015 09:57 PM
