Dark green/blackish "grease" on rim
I was washing my car today and while cleaning my rims, I found a dark green, almost black substance that had the consistency of grease, covering the inside of the rim. This was the front, driver-side rim. It had also gotten onto the strut. What is it and what do I need to fix?
Originally Posted by THT
I'm replacing the axle next weekend when I do the 5spd swap. Think it'll be okay for another 100 miles or so?
). Since you noticed the grease, the crack is likely recent.
It wasn't there last weekend when washed my car so it had to have happened in the last seven days. I'm not too worried but I need to ask Mike what else I should buy.
what could it be if you find alot of grease on top of the oil filter. i had my axles replaced already and the filter was instaled after the axle change. it was alot of grease too, like 2 fingers full of it. im lookin around and i have no visable leaks.
Just make sure that your car is not making a clicking/popping noise when turning.
That means the CV joint is already bad, and could totally fail at any point. You don't really want this to happen when you are driving.
THT, you should be ok. When this happened to my truck (due to excessive front-end lift - IFS), I busted the boots. I drove it for several hundreds of miles before getting them replaced and have had no issues from that. Just avoid wet, muddy, and unpaved roads as the debri can get kicked up into the cv joints.
I'm in the same boat too.. My driverside axle boot/cv boot is cracked and leaking grease. I think I've let it go so long that I'll probably just spring for the $60 raxle axle when I get around to changing it.
i think my axle need to be changed... whenever i turn it makes clicking noise yet i dont see any grease or anything like that.... how hard is it to change this ?? does the whole axle come iwth the boot and everything??
litch
123
Jan 4, 2024 07:01 PM
0m3nc0w
Sep 11, 2015 05:21 PM
