cleaning throttle body
Old Jul 20, 2005 | 03:45 PM
instil's Avatar
Roughly, how long would it take for me to clean my TB? I dont need a writeup, i need to know , is it a job that could easily be completed by a semi-handy rookie such as myself
Old Jul 20, 2005 | 04:04 PM
instil's Avatar
hrm...ive already seen this thread > http://forums.maxima.org/showthread.php?t=414103&page=1
but thats not making me any more confident. If i just clean everything out with moist paper towels and NO cans of spray cleaner, will i avoid effing things up/expensive repairs. I could just leave it dirty, but i wont
Old Jul 21, 2005 | 01:56 PM
traderfjp's Avatar
I would take it to a pro. I cleaned mine and now I have an issue with high idle. But if you want to do it then I would say that it shouldn't take more then 30 mintues unless you pull the intake and then it might take 1 hour or so. If I was to do it again I would remove the battery cable and not touch the buttrfly which means you need to pull the intake to do this.
Old Jul 21, 2005 | 05:35 PM
the paragon's Avatar
http://www.motorvate.ca/mvp.php/517
check out the link
Old Jul 21, 2005 | 06:11 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
that issue is only for the 3.5. i have cleaned mine a while back with no issues. it shouldnt take more than 15-20 minutes and that includes dismantling and reassebmly the intake. a dry cloth will only take up so much buildup, i would have a can of intake/carb cleaner and at least spray the rag. when you say moist, i hope you are not talking about using water. i would also try to do it when the motor is warm. the buildup will be easier to get off that way. as a side, i remember cleaning a 3.5 throttle body a while back and never had the issues that i see some complain about.
Old Jul 21, 2005 | 06:48 PM
siren001's Avatar
i have a 01 and clean the throttle body of my max today just with a cloth, a touched the butterfly to hold it open so i would get in there better, but when i put it back together my rpm went from 600 to 900-1000 is that normal? it made a strange noise the first time i started it up,
Old Jul 21, 2005 | 07:04 PM
sloppymax's Avatar
did you tighten all the clamps back down? if you have a leak then it would cause that.
Old Jul 21, 2005 | 07:57 PM
siren001's Avatar
the 2 rings the go around the hose on that connect to the throttle body are tight.
Old Jul 21, 2005 | 08:06 PM
siren001's Avatar
rechecked the connections 1 was a little loose but my idle is still about 900, could it be that i removed the snorkle off the air intake, and there was a sensor on the snorkle? but i thought that sensor isnt used, is there someway to bypass it if thats the problem
Old Jul 22, 2005 | 02:46 AM
instil's Avatar
Im going to attempt it because I know its going to be really dirty (52k) and i hate to just let it build and build, and slowly cause problems.
Old Jul 22, 2005 | 05:39 AM
sloppymax's Avatar
the air temp sensor is in the snorkel of the stock intake in your 01. it needs to read incoming air temp and cannot be removed unless you want the check engine light to trigger. removing that scoop is not going to help so i would suggest reattaching it. it helps pull cooler air over the radiator instead of the warm air that passes through the ac condenser and radiator.
220k+ A32
Sep 23, 2015 03:38 PM
bumpypickle
Sep 20, 2015 08:22 AM
97_GXE
Sep 15, 2015 06:47 AM
followthadollar
Sep 13, 2015 09:55 AM
Maxboy23
Sep 9, 2015 10:37 AM
