cleaning throttle body
hrm...ive already seen this thread > http://forums.maxima.org/showthread.php?t=414103&page=1
but thats not making me any more confident. If i just clean everything out with moist paper towels and NO cans of spray cleaner, will i avoid effing things up/expensive repairs. I could just leave it dirty, but i wont
I would take it to a pro. I cleaned mine and now I have an issue with high idle. But if you want to do it then I would say that it shouldn't take more then 30 mintues unless you pull the intake and then it might take 1 hour or so. If I was to do it again I would remove the battery cable and not touch the buttrfly which means you need to pull the intake to do this.
i have a 01 and clean the throttle body of my max today just with a cloth, a touched the butterfly to hold it open so i would get in there better, but when i put it back together my rpm went from 600 to 900-1000 is that normal? it made a strange noise the first time i started it up,
rechecked the connections 1 was a little loose but my idle is still about 900, could it be that i removed the snorkle off the air intake, and there was a sensor on the snorkle? but i thought that sensor isnt used, is there someway to bypass it if thats the problem
220k+ A32
09-23-2015 03:38 PM
97_GXE
09-15-2015 06:47 AM
