Engine won't go past 2500 rpm
I tried to search a bit but couldn't come up with too much. Real quick, 02 max with a 6sp. Just driving home from work and traffic was stop and go so I moved over to the far right lane and step on it to get off on an earlier exit. Something weird happened and now the car has the equivalent of a rev limiter at 2500 rpms. The engine just cuts power if I hit that on the tech.
Any ideas?
Thanks in advance
Any ideas?
Thanks in advance
Thanks for the help so far guys...
okay, so I went back out there to start it up and pull the car in the garage and I can't keep it running. It fires up and the tach bounces up and down slowly working it's way until it dies. Trying to "give it some gas" does not appear to help.
Any suggestions?
Any suggestions?
Your question has been answered. Your MAF needs replacing. If you are still unsure, you can run a diagnostic on it either at Autozone for free or the dealer for a labor charge.
GL
GL
Thanks...
I agree on the issue, it's just if I can't get the car started I really can't drive to get the part or take it to the dealership.
I was asking for suggestions on getting it running even if to limp along to the dealership.
Originally Posted by Luds
Thanks...
Thanks for the help...
God that part is expensive. I called around to 3 different stores and only Checker could get it. $280 and it would take 7 days. Gotta be kidding. Anyway, I'll figure something out.
-Thanks
-Thanks
One more question...
where exactly is the MAF?
theres wires going to it, on the intake... you can't miss the assembly.... on the straight part of the intake not the box....
Sorry... not to be an idiot
but where is it relative to the air filter, that might help me. Is it it the thing that is kind of diamond shaped sticking out of the tube just past the air filter?
yes its sticking out of the tube...
Right before you get to the metal pipes? (intake manifold?)
Cuz I have it down to 2 parts.
but, yea in between the metal pipes (manifold) and the filter box.... on a straight pipe.
ballerchris510
Sep 10, 2015 09:35 PM
