bose?
The amp is on the under side of the rear deck. Id say mount your amp on the back of the rear sear, run power and ground as normal. For remote, use the turn on wire at the Bose amp itself. As far as speaker wire, the Bose amp has 8 input wires and 8 output wires, a (+) and a (-) per speaker. I hate high level input, so Id run two high-low converters at the Bose amp, and then connect the output from your aftermarket amp to the wires at the rear deck going to each speaker, i.e. using the factory speaker wire to run from the rear deck to all the speakers to save you a bunch of work and useless hassle. (No factory system has RCA outputs, which is where the high-low converters come in. They convert speaker wire to female RCA.)
I must ask though. Why.
