Vg30DE Fuel injectors in my Vq30 ?
I found a J30 at the local pick N pull. My injectors went bad and my car is not running, so my question is do the vg30de injectors fit directly in place of my stock ones? With no or little mod? If modification is required please explain.
~Henry~
~Henry~
Originally Posted by hdiggeddy
well, there is an advantage to the VG injectors, I believe they are 370cc in comparison to our 290cc.
You didn't specify which car you have.
If it's a 4th gen then yes they'll probably drop right in with little effort (don't forget the silicone grease. But do not use anything petrolium based such as vaseline). If it's a 5th gen then certainly not.
Originally Posted by Kevlo911
Wooops, I am posting false info
Thanks for the correction Matt.
Actually you were correct. The FBJC101 injectors do flow 270cc @ 3.0 BAR. But since the returnless system runs at 3.5 BAR they instead operate at 315cc .
You didn't say what car you had in your first post, nor is it in your profile. Don't get angry at us because you didn't include the necessary info for us to answer your question.
Then SR20DEN answered your question even without the required info. He said yes. Check out his post. They are the same injectors (VG30DE and VQ30DE).
Originally Posted by SR20DEN
VQ30DE injectors 259cc @ 3.0 BAR
VQ30DE-K injectors 290cc @ 3.0 BAR (FBJC100)
VQ35DE (Maxima) injectors 315cc @ 3.5 BAR (FBJC101)
VQ35DE (350Z) injectors 335cc @ 3.5 BAR (FBJC100)
MY question was do any of these fit into my 95 maxima??????? I need new injectors and the size of them doesnt help me. I need to know what fits for my car. Thanks
jmlee44
Oct 2, 2022 02:13 PM
Forge277
Jun 13, 2016 09:26 PM
