VERY very low idle - need some help
Old Aug 16, 2005 | 05:12 PM
ChristheNite
Hey guys - my max seems like she's asking to be "put-down" lately...
Firstly: 1996 5Spd w/ 2000 trans. 135K miles.
Problem: very low idle, wayyy below 1K somewhere around 3-4 hundred. If i tap the gas it revs and then falls all the way to the point it almost stalls and then settles back at around 3-400 again. Stalled on me once after I reved it but other than that hasnt stalled yet. When the AC is switched on it revs right up to 800 and sits there perfectly...even my lights dim a little when its sitting at 3-400.
Anyone have any idea why this could be happening? I have the rear o2 code showing and I'm about 800 miles away from an oil change. Thanks for reading guys!!
Old Aug 16, 2005 | 05:16 PM
njmodi's Avatar
Do I get a tax break?
1. Clean out the TB and the IACV.
2. Once you have done that, adjust the base idle using the procedure in the stickies.
Old Aug 16, 2005 | 05:35 PM
TurboMax67
Check all vacuum lines.
Old Aug 16, 2005 | 05:55 PM
Kevlo911's Avatar
Kevlo for President
Make sure ECU screw is hte right position.
Old Aug 16, 2005 | 06:00 PM
ChristheNite
ahh kevlomight be right, i tired to pull cods this weekend and may have screw'd up the screw. What position should it be in?
Old Aug 16, 2005 | 06:11 PM
njmodi's Avatar
All the way anti-clockwise - don't twist too hard... but you should feel a definite stopping point.
TKHanson
Nov 24, 2018 01:39 AM
Unclejunebug
Apr 2, 2016 05:42 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
