lowest offset.
Old Sep 6, 2005 | 01:19 AM
A33 VQ30DEK's Avatar
lowest offset.
Hey guys,
I'm planning to purchase some used 18x9 with a +31mm offset all aroundSSR SP1 professors from this EVO owner. Is the offset to low or will i be okay? Has only gone lower then 31mm? Are their any pros are cons running such a low offset on a FWD?
Old Sep 6, 2005 | 07:53 AM
Ammi's Avatar
350 Detroit Muscle
rims are too wide and offset is too low especially for the fronts
Old Sep 6, 2005 | 01:23 PM
icelandmaxima's Avatar
Maxima Fanatic
Not gonna work
Nice wheels though
Old Sep 6, 2005 | 02:31 PM
Nismo's Avatar
Iilac has 25mm offset on 18x7.5" they look fine
Old Sep 6, 2005 | 02:50 PM
hacim105's Avatar
The offset should be fine. I have the G35 coupe wheels that are 18X8 with a 30mm offset. It actually makes the wheels look a million times better in the wheel well. But for width I'm not sure. I would imagine we should be able to use 9 inch wide wheels but I'm no expert.
So my conclusion is offset is fine, unsure about the width.
Old Sep 6, 2005 | 04:05 PM
BRAN808's Avatar
Yeah, but the thing is that the offset and width go hand in hand if the combo is going to work properly. I think it'll also depend on your drop also. I got 18" G35C's, but I'm lowered about 3.5" on Ksports. I have the stock Michellin 225/45/18's on the fronts, and I rub a little, but that's only on the liners.
Old Sep 7, 2005 | 12:52 AM
soo will they work or will they not?
this is like one in a life time deal right now.
This ish* is so confusing. i know 1fstmax fit 19*9.5 on his max with a 35mm offset. I wouldn't see why these wouldn't work.
Old Sep 7, 2005 | 07:05 AM
Ammi's Avatar
350 Detroit Muscle
big difference between 7.5" w/ 25mm offset and 9" w/ 25mm offset rims.
Old Sep 7, 2005 | 07:07 AM
Ammi's Avatar
350 Detroit Muscle
I doubt he's running that setup up fronts. Biggest I've seen up fronts were 17x9 w/ high offset. You can always try them and if they don't work out for you, sell them
Old Sep 7, 2005 | 09:02 AM
chris'smax's Avatar
my volks are 18x10's w/ a 43mm offset in the rear and i am almost certain they will fit. Even if they don't i can still sell them for a profit. You should do the same since it will be easy to sell those wheels since they aren't being made anymore
Old Sep 7, 2005 | 09:42 AM
hacim105's Avatar
I'm going to say yes they will fit. The 31mm offset will bring the wheel out almost flush with the fender. so there should be plenty of space.
Old Sep 7, 2005 | 12:33 PM
NewMaxSe's Avatar
I'm new to this forum so i can't post my own thread, but my question goes hand in hand. I want to know if an 18x8.5 with a 24mm offset will work on the back of my 02 max?? Any help would be muchly appreciated.
Old Sep 7, 2005 | 02:41 PM
Ammi's Avatar
350 Detroit Muscle
more room in the rear than front. I doubt you can mount those up front. Also depends on what kind of drop your car has too.
Old Sep 7, 2005 | 03:28 PM
steven88's Avatar
Need A Light?
Brian, i think 9 inch wide with 255 wide tires would work....I know Larrio fit some 9 wide with 265 tires on 35mm offset...he was dropped on Sprints....and you are dropped on S techs which are about the same drop as sprints....if it rubs u can always roll yer fenders...
Old Sep 8, 2005 | 11:39 AM
NISMAX03's Avatar
I have the OEM G35 Coupe rims (18x8 30 offset) with 235/40/18 tires. The front is flush with the fender and the rear has about an inch of space. I think the 9" rims would fit in the rear, but doubt if it would fit up front.
Old Sep 13, 2005 | 05:12 PM
irish44j's Avatar
retired moderator
18x9 with that offset will stick out a little (about 1/2") from the front fenderwell.
18x8 with 30mm offset sits flush
Old Sep 14, 2005 | 11:49 PM
damn... i wanted these wheels tooo. sick of the volks.
Old Sep 15, 2005 | 08:20 AM
Maxima Fanatic
I just got some 17x9 with 38 offset we'll see how that works. Might have to roll my fenders if I want to tuck It will be close
jskirwin
Jun 8, 2016 08:49 AM
umnitza
Sep 1, 2015 01:03 PM
xUNIxPanther
Aug 5, 2015 09:31 AM
MAC
Oct 8, 2001 10:05 PM
