Anyone install Yellow Capsules from HIDTech.com??
Yes, ours are glued together just like the 5th gen. $20 to search is golden fellas, here's a freebie on me!! http://home.comcast.net/~dinhdu/index.html
He has real hid bulbs and ballasts for his fogs but it will work very well with the stock h3 also. I'm looking at this as a future mod as well.
thanks for the link, but i think a lot of those steps may be unnecessary for people using regular H3 halogen bulbs. But one thing that's confusing is if we use the H3 capsules http://hidtech.com/images/02152.jpg then how will it stay put? Is it just a simple fit? and will it also fit the bulb shield? I'll order these soon and see what happens.
It is a press fit, you work the capsule into the socket carefully with a pair of needle nose. And yes he showed putting the bulb shield back on it. Get the regular h3 capsule for regular h3 bulbs.
Originally Posted by 1NICEMAX
You think it will be brighter using HID H3 than using Halogen H3?
And since it's a press fit, there's no need to open up the lens. Just stick the capsule through the hole... or am I wrong?
The H3 capsule will not have a bracket installed. You can request one at the time of purchase from HIDTech but you will then have to find a method to keep the bracket attached to the capsule yourself. Do yourself a favor and do as rsly33 states and just get the 9006 capsules. Those will have the bracket already attached. As for just being able to "press" the capsule through the H3 bulb opening, that is not going to happen. You must open the foglight in order to fit the capsule in regardless if you use H3 or 9006 capsule size. As posted above, use my TUT for step by step instructions for this MOD.
Hey meanbean, I'm thinking about getting the 9006 capsules since they already come with the brackets installed. But I have a couple of questions:
1. Will the bulb shield stay put or should I use krazy glue to secure the shield.
2. Is it okay to touch the capsule with our oily fingers?
3. Will using a 9006 capsule on a regular H3 bulb have any negative effects due to the size difference?
doctorpullit
Jul 20, 2019 09:31 PM
MaxLife17
Jun 27, 2019 01:37 PM
