Engine making noise in 'on' position...
Old Sep 7, 2005 | 06:26 PM
crappopotamus's Avatar
No, not while started! I was pulling an engine code, and you know how you put the key to the 'on' position... while i was doing this, i noticed a loud whining noise, and discovered its coming from underneath the battery or behind the driver side front wheel well! I've never noticed it before... It sounds like a fan or something. What's down there? Anyone notice it before?
As far as engine code, i got a 5-5 (normal). Probably cause i turned off the car when i first heard the noise. I will get the code when it comes back.
Old Sep 7, 2005 | 08:39 PM
|Bijan|'s Avatar
UCF Lexus
Automatic or 5spd?
Old Sep 7, 2005 | 08:46 PM
NY 95 VQ30DE's Avatar
I always thought that noise was the fuel pump .....could be wrong tho. Only on for about a sec, then quiet again.
Old Sep 7, 2005 | 08:53 PM
|Bijan|'s Avatar
UCF Lexus
The fuel pump is in the rear, it could be the fuse clicking though? I used to hear it on my automatic, I really havent listened for it on this one.
Old Sep 7, 2005 | 08:55 PM
I know the pump is in the rear, but he could think its from the front because the niose is from under the car...
Old Sep 7, 2005 | 09:25 PM
maximazation's Avatar
TPS maybe?
Old Sep 8, 2005 | 10:50 AM
its an auto.
its a constant noise while the car is 'on', but it seems to go away once i start it. as a side note, i'm having trouble starting the car. it seems to really struggle.
Old Sep 9, 2005 | 05:38 PM
bump. engine code is 5-5 unknown :| probably gonna have to take this one to the pros.
and the noise is definately coming from the front. i took out the airbox/intake assembly to listen, and it seems like its under the front intake piping...
Old Sep 9, 2005 | 05:47 PM
njmodi's Avatar
Do I get a tax break?
Engine code 0505 means that the ECU has not detected any failures, i.e everything is working as expected.
The noise could be the idle air control valve....
Old Sep 14, 2005 | 10:23 AM
bump... any more ideas?
Hondarydr
Dec 30, 2024 06:15 PM
boomerbrian
Nov 8, 2015 05:10 PM
maxinout93
Oct 27, 2015 01:29 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
