Engine making noise in 'on' position...
No, not while started! I was pulling an engine code, and you know how you put the key to the 'on' position... while i was doing this, i noticed a loud whining noise, and discovered its coming from underneath the battery or behind the driver side front wheel well! I've never noticed it before... It sounds like a fan or something. What's down there? Anyone notice it before?
As far as engine code, i got a 5-5 (normal). Probably cause i turned off the car when i first heard the noise. I will get the code when it comes back.
bump. engine code is 5-5 unknown :| probably gonna have to take this one to the pros.
and the noise is definately coming from the front. i took out the airbox/intake assembly to listen, and it seems like its under the front intake piping...
The noise could be the idle air control valve....
boomerbrian
11-08-2015 05:10 PM
MaximaDrvr
08-19-2015 08:20 PM
