How do you change the fog light bulbs?
Did ya try taking off the splash guards?
This write-up is for a 2002-2003, but it might be similar:
http://www.moodym.com/maxima/tech/foglight.html
This should do:
http://www.innerbean.com/housecor/
Originally Posted by higney85
minor detail... its a 2000- all the links seem to be for 02-03. Sorry but does anyone have suggestions for a 00?
Pull back the splash guard under the housing. you will see a bolt that threads into the bottom of the housing, take it out. Then there is a white plastic piece on top of the housing that you need to just push out of its hole and then the housing comes right out. the rest is pretty simple, I would just put your hand in front of the light when you push it out because it can hit the ground and break.
vingodine
45
May 21, 2016 12:46 PM
Viralkill
Aug 17, 2015 10:54 AM
MikesChevelle
Aug 6, 2015 11:36 AM
