Busted VIAS? Torque Converter? Dammit...what's wrong with my car?
Well, today is the first time I can say that there is something seriously wrong with my car. 50k miles on the ticker and all I've had to show for it was a busted secondary O2 sensor. But today, while I was driving I noticed a lack of grunt initially. Then when I ht the highway, I floored it and the car shifted on the spot, gave me a good dose of shift shock, but...it wouldnt accel. for sh*t past 4K RPM. The needle was barely moving up. Its not my MAF because the low-end seems all dandy and revs past 3-4RPM just fine (it redlines, even). But when Im in highway speeds, its downright dead past 4K RPM.
I knew another person with this problem and he had his torque converter and transmission replaced. And if it were the VIAS, I would feel a loss of power throughout all gears, correct?
Dammit...just dammit. Help!
Edit: By the way, everything was just fine with the car yesterday, as far as I remember.
Well it's certainly weird. I just did a quick jolt from 60-80 and it only took the car ~4 seconds to hit 80. So now, everything's fine. Off the line, the car stills pull hard as hell...
Now what's weird is that when I did the 60-80 test, I paid attention to the RPM needle and it still wasn't moving...it was just barely creeping. It'll shoot past 3K and then just crawl once it's past 4.
I dunno. This is very weird.
Originally Posted by Metal Maxima
Please read that again and asses the logistics of that comment.
ANYWAY.... check out your cat. I had the same thing, thought it was the tranny, went through a bunch of junk and found out I had a fried kitty! Another thing: You didn't happen to get the bright idea of removing the air hose from the intake to the valve cover and capping the intake end and slapping a filter on the other end, did you? Just curious because that's how I ended up with the same crap.
Hate to say it but your MAF is NOT ok. It's a common problem with 00-01 cars, our mafs just start to suck over time.
4k is where the maf starts to choke. get a 2Y001 or AD210 maf and your problem will go away.
Edit: Hahaha, Metal.
Originally Posted by Shogunsc4
From what I heard, the VIAS only affects power up top (5k+ rpm).
Lakersallday24
Jun 16, 2019 01:35 AM
SmokinMax02
18
Sep 11, 2015 12:25 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
yat70458
Aug 3, 2015 01:16 PM
