Best way to wire DVC 4ohm sub to 2channel amp
Old Oct 5, 2005 | 08:26 PM
Majestic's Avatar
Yahhhhhhh
Hey ppl. I have a 2 channel Rockford Fosgate 501s amp. The amp specs are:
125 watts RMS x 2 at 4 ohms
250 watts RMS x 2 at 2 ohms
500 watts RMS x 1 at 4 ohms in bridged mode
stereo or bridged mono output
4-ohm stable in bridged mode
Tri-Way capable
I just blew the coils on a Infinity Reference 1230w.
I just bought an Audiobahn AW1206T. The RMS is 1100(so they say). It has dual 4ohm voice coils. My question is: What is the best and loudest way to run this sub to this amplifier? From what the manaul says, the amp is not 1ohm stable. I guess what I'm trying to say is how can I produce a 4 ohm load to this amp with both voice coils being active?
Old Oct 5, 2005 | 08:36 PM
AscendantMax's Avatar
since the sub is dual 4, you can either wire it to 2 or 8 ohms, parallel and series wiring, respectively.
i'd return the sub and get a dual 2 version. then wire the coils into a series (to get 4 ohms), and bridge the amp to power it.
Old Oct 5, 2005 | 08:58 PM
kpr10is's Avatar
+1 to the above post. The only way to wire that would be one coil per channel, which kinda sucks.
Old Oct 5, 2005 | 09:13 PM
yeah, or if you don't want to return the sub, get a RCA splitter and run one R to two Rs (or one L to two L) so that the coils will get the same signal.
Old Oct 6, 2005 | 12:40 AM
505max94se's Avatar
run it at 4 ohm stereo (it's the only way, not much power though)
one voice coil to one channel (dvc, 2ch)
I'd get a different sub or amp.
Old Oct 6, 2005 | 04:11 PM
ehh...if he ran it 4 ohm stereo...each coil might get different signals...instead of 1 clean one...
Old Oct 6, 2005 | 05:22 PM
Majestic's Avatar
Yahhhhhhh
Thanks guys. This amp's manual says not to present a bridged signal that is lower than 4ohms....However I hooked up my friend's Sony's(2 12s) in parallel and presented a 2ohm load and it works fine. If it has been working fine for a couple days is it fine to keep it like that? Somebody told me to just throw in some lower amp fuses to be safe. How true is this?
Old Oct 6, 2005 | 05:37 PM
filtor1's Avatar
Will it work, yes, is it a good idea, no. Your solution will take out the weaker of the two, subs or amp.
Old Oct 6, 2005 | 07:02 PM
Tigger's Avatar
I have been running a Alpine type R DVC wired at 2 ohms off of a Fosgate 500a2 for 3 years now (in my Jeep). The amp will get very hot and go into thermal shutdown after about 3 songs if there is not a lot off cooling (ie, back seat donw over it). But if the seat is up, the amp will run for several hours before shutting down.
I know it is not recommended, but it works.
I also do the same with my PPI PC2600 and the same sub. It has a fan and has never shut down.
Best option is to exchange the sub or get an amp that is 2 ohm stable.
Old Aug 8, 2011 | 01:01 AM
PHXBird's Avatar
PPL I need help I have a Majestic amp and a pair of Rockford Fosgate P3 12in. I would like to know how to wire it so that I get 1 ohm
The subs are Dual 4 ohm 1000 watts 500 RMS each
The amp is 2000 watts peak
1000 watts x 1ch Rms @ 1ohm
600 watts x 1 ch Rms @ 2ohm
400 watts x1 ch Rms @4ohm
How do I get the most out of this amp?
Old Aug 8, 2011 | 07:03 AM
Batxel's Avatar
blah
this site has a nice layout with pics and diagrams. Put in 2 speakers and dual voice coil 4 ohm...
http://www.the12volt.com/caraudio/wo...igurations.asp
Old Aug 8, 2011 | 01:39 PM
djfrestyl's Avatar
Suspension Yoda
Oh look, a 6 year old thread.
Here's another site that has wiring configurations:
http://www.crutchfield.com/S-LNFd7Yw...rs_wiring.html
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
