Rpm flucuating @ idle ..
Well basically ive been driving the car and i just noticed that sometimes when i come to a stop the rpms are at 700 where they should be. But then i noticed the car starts to get slightly rougher and i looked at the idle and it was at 900. Now while i was at a stop light the cel popped on 0302. Of course the idle was at 900 when it happened. THe throttle body has been cleaned new ngk oem plat plugs, air filter,fuel filter, intake manifold (cleaned) , egr port cleaned. Egr celenoid replaced 3 times. I dont know whats left to do. If anyone can shed some light on this issue i would appreciate it, thanks.
0302
Diagnostic Trouble code 0302 points to a problem with the Exhaust Gas Recirculation system. The malfunction is detected by the Engine Control Module when no EGR flow is detected under conditions which call for EGR. Possible causes include:
- The electrical harness or connectors (valve circuit open or shorted)
- The EGR valve is stuck closed
- Weak or dead battery
- The EGR passage is clogged
- Faulty EGR temperature sensor circuit
- A leak somewhere in the exhaust system
The EGR Volume Control Valve may be tested with an ohmmeter. Disconnect the electrical connector. Looking at the connector half which is attached to the EGRVCV with the latch at the 12 o'clock position you will see two rows of three terminals. The top row is numbered 1-3, right to left. The bottom row is numbered 4-6, right to left. Measure the resistance between these terminal pairs:
2 1
2 3
5 4
5 6
... all resistance values should be 20.9-23.1 ohms at 68 degrees F.
Reconnect the EGRVCV connector halves. Turn the ignition switch ON OFF repeatedly. Verify that the EGRVCV shaft moves smoothly forward backward according to the ignition switch position.
The Exhaust Gas Temperature Sensor may be tested with an ohmmeter. The specifications are ...
- at 32 degrees F, 0.68-1.11 Megohms
- at 122 degrees F, 0.09-0.12 Megohms
- at 212 degrees F, 0.017-0.024 Megohms
i would also check ur TPS (throttle position sensor)
mine did that when it was bad
2 1
2 3
5 4
5 6
Unclejunebug
Apr 2, 2016 05:42 AM
Need help
23
Oct 2, 2015 08:56 AM
