$$$ Timing Belt Replacement
Old Oct 20, 2005 | 07:01 PM
i30dvr's Avatar
I have 70000 miles on my i30t and was wondering about how much a timing belt would be to replace? Also any other service checks i should do at this mileage? Thanks
Old Oct 20, 2005 | 07:03 PM
Jeff92se's Avatar
I'm needing a caw
Aw man. It's expensive as all hell!
Old Oct 20, 2005 | 07:09 PM
matty's Avatar
No timing belt in the VQ30. Its a chain and should last the life of the engine
-matt
Old Oct 20, 2005 | 07:10 PM
ThisMaxIsTight's Avatar
vq's dont have timing belts, they have timing chains ... ??
Old Oct 20, 2005 | 07:11 PM
mtrai760's Avatar
'Trynna' is not a word
wait, wait.... nope...
Old Oct 20, 2005 | 07:19 PM
Fr33way™'s Avatar
Wild for Width
The major service intervals are 60K.
Old Oct 20, 2005 | 07:37 PM
2 Da Max's Avatar
its part number 098532
the dealer should carry it..... along with other misc things....
Old Oct 20, 2005 | 08:38 PM
Bobo's Avatar
Since you missed the major service at 60K, you shouldn't do anything for another 50K, then its ok to catch up at 120K.
Old Oct 20, 2005 | 08:43 PM
gtr_rider's Avatar
192.168.1.1
UL09-8532 to be exact..
Old Oct 20, 2005 | 10:02 PM
99grnmaxgxe's Avatar
You don't need to replace the timing chain...check the stickys.
Old Oct 21, 2005 | 05:04 AM
i30dvr's Avatar
ok, matty your making me confused. I thought our motors (VQ30) has timing belts and the new 3.5 has a timing chain????
Old Oct 21, 2005 | 05:16 AM
gtr_rider's Avatar
192.168.1.1
It contains both
Old Oct 21, 2005 | 06:53 AM
i30dvr's Avatar
so the only thing i need to replace is my timing belt?
Old Oct 21, 2005 | 06:59 AM
SkinnyMax's Avatar
maxima no more
how are you still confused, its been said atleast 3 times that we have chains not belts. It was an honest question at first but the fact that you still think our engines have a belt, READ THE DAMN STICKIES
Old Oct 21, 2005 | 07:01 AM
2 Da Max's Avatar
and the tensioner
Old Oct 21, 2005 | 07:04 AM
Stephen Max's Avatar
The carburetors should be rejetted at the same time you change your timing belt.
Old Oct 21, 2005 | 07:06 AM
Bobo's Avatar
Also replace the distributor cap and spark plug wires. That should have been done at 60K.
Old Oct 21, 2005 | 07:20 AM
C MAX's Avatar
also make sure you adjust the bov lol
Old Oct 21, 2005 | 07:27 AM
Bobo's Avatar
Well I will try and give you a hand. What year is your car and what mileage did it have on it when you bought it? What maintenance have you done to it?
I suspect the car hasn't had the 60K service, so that should be done for starters.
If the following have not been replaced by you, they probably should: spark plugs, fuel filter, PCV valve, air filter, radiator coolant, automatic transmission flushed, power steering fluid replaced (turkey baster method is ok), brakes flushed if no brake work has been done yet, rotate tires.
There are a lot of inspections that are done at 60K and these should certainly be done: exhaust, suspension, steering, CV boots, hoses, belts, lights etc.
Read the stickies and FAQs and buy a Haynes manual if there is one available for you year.
Old Oct 21, 2005 | 07:40 AM
Bobo's Avatar
You should also clean your fuel injectors if you haven't done that before. Consider using Chevron Techron, BG44K or Gumout Regane before your next oil change.
You also might want to check out the following products: AutoRX (www.auto-rx.com), Lubecontrol LC20 & FP60 (www.lubecontrol.com)
Good luck!
Old Oct 21, 2005 | 07:43 AM
GodFather's Avatar
Made in Taiwan
poor guy, got clowned so bad over here. let's staright him out.
"there are no timing belts on our VQ's," we'll say this for the LAST TIME!!!!!
if you mention the word "timing belt" again, I'll find your location and go there just kick your *****. we only have a timing chain, and it shouldn't need to be replaced for the engine's lifespan. get that straight before you nut again on this forum...
Old Oct 21, 2005 | 10:06 AM
i30dvr's Avatar
wtf, i'm not retarded, but i'm trying to find out the facts on what i should do for maintenance
Old Oct 21, 2005 | 10:15 AM
Bobo's Avatar
Perhaps you are retarded! After 9 or 10 months on this website and a little research, one would think you wouldn't ask such an inane question.
Now get with the program and do some research. Spoonfeeding 101 is not offered here!
You could have thanked me for the feedback I provided in my previous post but I guess that would be asking too much!
Old Oct 21, 2005 | 10:25 AM
i30dvr's Avatar
no definetely not, i just wanted to make sure my statement about my car was correct and getting mixed replies have made me question myself
Old Oct 21, 2005 | 10:31 AM
Bobo's Avatar
You may be starting to come around ever so slightly and have every reason to question yourself! You still haven't thanked me for the input I gave you, which is the last constructive feedback you will get from me unless I see an attitude adjustment.
Old Oct 21, 2005 | 10:38 AM
C MAX's Avatar
also learn to accept humor when you post something funny. but the serious question to your answer is 91-92 had timing chains on se 190hp model only and 95-99 has timing chain on all models that require no maintenance unless they go bad which is very rare. timing belts are made of rubber which crack and break in time, and the timing chain is a chain like a bicycle that doesnt wear.
Old Oct 22, 2005 | 10:48 AM
95jr6708's Avatar
Kinda seems like it...
Old Oct 22, 2005 | 10:58 AM
njmaxseltd's Avatar
This thread is... :
Old Oct 22, 2005 | 11:23 AM
gtr_rider's Avatar
192.168.1.1
Originally Posted by njmaxseltd
This thread is... :
maybe later..
Old Oct 22, 2005 | 11:32 AM
jwmaxse's Avatar
Not that it matters too much in this case, but the VE was from 92-94 SE's and had a timing chain, 89-94 GXE's and 89-91 SE's had the VG and had timing belts.
Hondarydr
Dec 30, 2024 06:15 PM
PH98I30
19
Jun 13, 2016 02:38 PM
stromm
Aug 27, 2015 04:13 PM
erictown
Aug 20, 2015 08:01 AM
Maxima2010 Prem
Aug 13, 2015 11:34 AM
