ordered blue aluminum cold air intake for Max 95...won't fit? help?
Old Oct 22, 2005 | 04:41 PM
SiliconStyleS9's Avatar
Hi. I looked at the "how to" section, but it shows only how to install an intake on a 5th gen Max. I got this intake: http://cgi.ebay.com/ebaymotors/95-99...QQcmdZViewItem
The part looks identical except that the pipe is bent the other way so that it is supposedly compatible with the 95-99 Maxima's. Can someone please supply me with pictures? Thanks. My friend and I tried to do it, but there wasn't enough room, it seemed, with the bypass and sensor and all.
and you all know what it looks like under the hood.
It looks VERY similar to this Cattman CAI.
http://www.cattman.com/img/prod/dsc_...20g5%20cai.jpg
Old Oct 22, 2005 | 04:45 PM
Mxrider52's Avatar
I support for what?
Old Oct 22, 2005 | 05:40 PM
Kevlo911's Avatar
Kevlo for President
https://maxima.org/modules.php?name=CAI
And the 5th gen how to is almost exactly the same.
Old Oct 22, 2005 | 05:47 PM
so I need to cut a hole in my car in order to install it? no wonder...
Old Oct 22, 2005 | 05:58 PM
Kevlo911's Avatar
Kevlo for President
Yes.
Mine installed.
Old Oct 22, 2005 | 06:25 PM
Mxrider52's Avatar
I support for what?
I am sure buying just the normal cold air intake would give the same results instead of cutting into your body
Old Oct 22, 2005 | 06:30 PM
Kevlo911's Avatar
Kevlo for President
No, this is the only TRUE cold air intake for the Max.
Old Oct 22, 2005 | 06:32 PM
Dubbya's Avatar
VK56 Inside
Is there really a "true" cold air intake for the maxima? I can remember a post a long time ago from a guy who put thermal sensors in the engine bay and on the front bumper. At highway speed all of the sensors read the same air temp.
Old Oct 22, 2005 | 07:08 PM
eckohb's Avatar
thats wrong, because the ambient temps of the true CAI were cooler than the injen or the short ram.
Old Oct 24, 2005 | 10:27 PM
eyesack killa's Avatar
... how much more airflow can u get INSIDE ur fender wall than in ur semi-ventilated engine bay??? my injen works just fine, thanks! u can also buy a heat shield! or make one urself! cutting holes = waste of time IMO.
Old Oct 24, 2005 | 10:34 PM
SchismistiC's Avatar
You guys are right about the true air intake. I bought a cheapy intake like that one damn it was a ***** cutting a hole into the body. I was like **** it im doing too much **** to it. So i just bought myself a injen. I also think it is a waste of time but, you have fun doing it.
Old Oct 24, 2005 | 10:40 PM
NmexMAX's Avatar
dot dot dot ...
Airflow hre isn't as important, as these engines are N/A, or at least the one in question.
It's more a matter of intake air temperature.
I'm sure your injen works just dandy
Old Oct 24, 2005 | 10:43 PM
eckohb's Avatar
im sure his injen sucks
Old Oct 25, 2005 | 04:16 AM
chenzarino's Avatar
Well, all intakes suck when it comes down to it...
Old Oct 25, 2005 | 08:06 AM
eckohb's Avatar
hahahaha...haha...ha...
Old Oct 25, 2005 | 08:15 AM
NmexMAX's Avatar
dot dot dot ...
Even stock .
Old Oct 25, 2005 | 09:04 AM
Caracicatriz's Avatar
What was that?
It's not hard at all to install. Just buy the drill attachment from home depot and drill a hole. The installation only took me about an hour. I also didn't have any directions.
Old Oct 25, 2005 | 10:00 AM
ThisMaxIsTight's Avatar
keep it stock .... why do people put intakes on ... they slow you down .... the stock maxima intake creates the most power on the power curve
Old Oct 25, 2005 | 04:30 PM
lol yeah u r right about temp not flow... if i had unlimited money i'd just make a total custom thru-the-headlight type thingy that'd be real cold. o well ill keep workin...
Old Oct 25, 2005 | 04:52 PM
Kevlo911's Avatar
Kevlo for President
Wrong. The PR CAI pipe with the Stock midpipe results in the most power all around .
That is why I spent months looking for one of these after my 00vi swap
I can install the PR CAI in 35min or less. It does not take a long time to drill a hole
Old Oct 25, 2005 | 06:15 PM
NmexMAX's Avatar
dot dot dot ...
Why not get the 95 version that has an extra resonator ... Or would that take another few months ...
Old Oct 25, 2005 | 06:29 PM
Kevlo911's Avatar
Kevlo for President
4th gen one doesnt fit anymore after the 00vi
Old Oct 25, 2005 | 06:38 PM
NmexMAX's Avatar
dot dot dot ...
That's why the fastest VQ30 N/A has a stock intake
Old Oct 25, 2005 | 08:14 PM
maxS
seriously doubt it...
Old Oct 25, 2005 | 08:17 PM
Nissan 6's Avatar
Old Oct 25, 2005 | 08:18 PM
NmexMAX's Avatar
dot dot dot ...
Ever hear of sarcasm .. note the YEAHRIGHT smiley ... My point was he's wrong because all of the fastest VQ30s have intakes ..
Kevlo911's Avatar
Kevlo for President
Uhh, Hence the
Old Oct 26, 2005 | 10:30 AM
eckohb's Avatar
buncha stupids here obviously. I'll be drilling the hole in my fender this weekend with the stock airbox. Had it on my last set up with the 00VI, and plan to do it again.
Old Oct 26, 2005 | 11:18 AM
What was that?
Is the throttle response better with the stock midpipe on there?
Old Oct 26, 2005 | 11:20 AM
NmexMAX's Avatar
dot dot dot ...
Some say this is so ...
95Maxi
Aug 29, 2015 09:38 PM
bc992164
Aug 26, 2015 12:19 PM
cheftoo
Aug 20, 2015 05:17 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
