ignition timing on a Maxima 93
Old May 31, 2001 | 08:16 PM
K & N's Avatar
I read somewhere that you can gain Horse power by changing your ignition timing from 15 to 20. How much would I gain and how is it done. Thanks.
Old May 31, 2001 | 08:27 PM
FitzMax's Avatar
I read a post not too long ago in which someone said that people with the VE engines (myself) could not change the timing because we have a timing chain instaed of a belt. Is this true? I wanted to change the timing on mine but now I am not sure. Oh yeah and to answer you question, increasing the timing will not really give much gain in the HP department but may give you better throttle response.
Old Jun 2, 2001 | 07:32 AM
K & N's Avatar
I have a timing belt on mine, a fairly new one. Is it possible for me to change or do I need to have it done somewhere?
Old Jun 2, 2001 | 08:38 AM
FitzMax's Avatar
You can do it, it is just easier to do with a timing gun. Most shops have these but they can be purchsed too. I am unsure of the price.
Old Jun 2, 2001 | 10:02 PM
bigjay's Avatar
the best way to do it is to,
Buy the computer upgrade from jwt, it is better for your car than f@$king with your timeing
Old Jun 3, 2001 | 12:34 AM
FitzMax's Avatar
Re: the best way to do it is to,
Hehehe, very true, but I would much rather spend $0.00 on changing the timing than $400-500 for a new ECU upgrade that really doesn't do much unless you car is heavily modded or unless you are running NOS.
Old Jun 3, 2001 | 09:55 AM
Nismo87SE's Avatar
Well....
The JWT ECU would have more torque gains that you could ever get from playing with the base timing. Not to mention the higher rev limiter and better air/fuel ratios you can't do unless you buy a fuel controller. I would say the JWT ECU makes as big a difference as the Y pipe does. But in the mean time I'd guess that 18-19*BTDC should yeild good results. As long as the car runs on 91+ octane, there should be no trouble in advancing the timing.
Old Jun 4, 2001 | 11:57 AM
Maximum5spd's Avatar
hey guys, You started the post with Ignition timing which has to do with your spark plugs and wires, and the jumped to belt timing. The ignition timing maybe gains .5-2hp , which is no way on earth ull notice that. I have it done and didnt notice a thing. And as far increasing your timing, he is right might as well buy the ECU because little over or little less can have very high damage to your engine i dont think its worse the 3-5hp.
Old Jun 5, 2001 | 06:16 PM
K & N's Avatar
Hey I have been looking for tail light covers like those, where did you get them?
Old Jun 5, 2001 | 06:56 PM
The Flem's Avatar
ok, it looks like there is a lot of confusion as to what timing is on this board.
timing is the point at which the spark plug is fired in relation to the piston position
timing can only be adjusted on an engine with a distributor. VG's have distributors, VE's dont, it is computer controlled ignition. You will need a chip to modify it.
you can buy a timing gun cheap, 20 bucks at walmart. I dont mean to sound condecending, but most mechanics I know will laugh at you if you bring in a Maxima to have the timing bumped up a few degrees. the engine will start pinging if its too high, and higher grade gasoline is required. I've talked to some people who run the Baja 500, and they often "de tune" their engine by bumping the timing down so it can run on cheap quality gas from Mexico.
You don't really gain any horsepower, but it helps off the line with more ignition advance since the timing is already in the position for higher revs. timing increases as the rpms do, so the spark is ready for the piston once it reaches compression levels ready for detonation.
Old Jun 5, 2001 | 09:34 PM
FitzMax's Avatar
If the timig on a VE cannot be changed, then how come some people with the VE have said they did it? Are they changing something else that they believe is the timing but is actually not....I have had people tell me different stories here and all have evidence to back up their sides. *******ONCE AND FOR ALL********** Can the timing be adjusted on VE MAximas?!?!?!?!?!?!?!?!?!?!?!?!?!? Thank you.
Old Jun 5, 2001 | 09:44 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
I could've sworn....
some VE guys had adjusted the timing??? didn't Czar do his?
Old Jun 6, 2001 | 04:15 AM
Dave S's Avatar
According to the FSM, ignition timing on the VE is adjusted by rotating the crank position sensor, which is located on the right end of the front cylinder bank (near the fuel pressure reg). There are several ways to pick up the signal from the #1 spark plug (back left).
Old Jun 6, 2001 | 12:38 PM
The Flem's Avatar
ok, my bad, I didn't realize the ve engine had a cps in the same location as a distributor. I have a VG and havent looked at a VE, and most vehicles have the CPS on the harmonic balancer or on the flywheel.
If thats true, it can be adjusted, but I would think it would really screw up a lot of stuff. Wouldn't the CPS tell the injectors when to fire?
Finkle
Sep 27, 2015 09:53 PM
laparka66
Aug 6, 2015 09:36 AM
maxima297
Aug 3, 2015 12:50 PM
