255/45/r18 snows too big?? 2004 SE
Old Oct 28, 2005 | 08:37 PM
johnsa's Avatar
would these be too large for 2004 SE..??? what about 225/55/17
Old Oct 28, 2005 | 09:06 PM
KCMAXX's Avatar
KC's FINEST
OEM is 245/45-18. I wouldnt go any bigger. Read the Sticky. Why would you wanna go wider for snow...?
Old Oct 28, 2005 | 09:15 PM
mtrai760's Avatar
'Trynna' is not a word
Wider tires perform worse in the snow.
Old Oct 30, 2005 | 11:02 AM
CanadianMoFo's Avatar
225/55-17 are the proper size to use. That's the same size that comes on the SL's. Get a cheapo steel rim and you'll be set for winter.
CM
Old Oct 30, 2005 | 12:25 PM
Glude's Avatar
Im running a 255/35 on my new 19s and the handling is much better. that size might be to big though.
Old Oct 30, 2005 | 12:39 PM
KCMAXX's Avatar
KC's FINEST
Man, you cant tell us and not show us!!
Post some pics...
Old Oct 30, 2005 | 12:50 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
yea man, I have 255 on a 9 inch wide rim... i tought that size was for 9-9.5 wide..
Old Oct 30, 2005 | 01:02 PM
Glude's Avatar
Well im running a 255/35/19 on my car and it looks great. I was a little worried the 255 would be to wide for 8.5 inch wheel so definately not on our stock 18x7.5 wheels.
Old Oct 30, 2005 | 07:16 PM
eyecon7's Avatar
Yo glude i want some pics cause in my thread some one posted it with 255/40/19 and then i kinda droped the idea of the 255 i really want to see it in a 35 series
Old Nov 2, 2005 | 05:27 PM
KCMAXX's Avatar
KC's FINEST
I posted the 255/40's. They fit but I agree, it looks kinda 4x4! But were talking about on a 6th gen, I sold my 19's to a 5th.I was running 255/40/19's on my 6th and they fit great.
Old Nov 2, 2005 | 06:17 PM
NickelM16's Avatar
I know nothing about tiers rim sizes but good thing u guys are here to saves us
Old Nov 3, 2005 | 02:19 PM
Champ2433's Avatar
For snows? Those are much too big for snow tires. You will float and have a lot of trouble turning with snow tires that large. In a FWD car this will be even worse as the yalready have a tendency to push the nose. You should stick with atleast OEM size or even drop down on the width if they will fit your rims. You should check your rims, or owners manual for rim width, then check the tire specs to see what size rims they will fit. Tirerack is a great spot to find specs on tires.
Old Nov 3, 2005 | 02:54 PM
CCS2k1Max's Avatar
You need to increase the ground pressure. I'd go down a size/up a series to try to keep the odo/speedometer within calibration.
Miket2006
Mar 1, 2021 03:55 AM
gigabyte
Jan 6, 2017 06:05 PM
hayne
Oct 5, 2015 11:53 AM
MichMaxFan
Sep 30, 2015 09:18 AM
