5th Gen 6spd in a 4th Gen
Appears it isn't so easy - http://forums.maxima.org/showthread....ghlight=6speed
From what I understand, it requires removing one of the existing transmission mounts and then fabricating and welding a new one for the 6spd. The first five gears are almost the same on the 5MT and the 6MT, the main difference is that the 6MT has an additional overdrive and some extra weight. It really all depends on what your priorities are...for racing, the 5MT is what you'd probably want; for an everyday highway cruiser, you might want the 6MT.
Originally Posted by maxS
6spd hard to swap in... you ppl are wimps no offence... 5spd is old skool, 6th is new age.
Originally Posted by NmexMAX
The only advantage is very very very slight better gas mielage.
Originally Posted by darklegend06
I was woundering if it is better to swapping to a VQ35 engine with the 6spd trans from a 2K2 maxima. I'm planning on keeping my car for a LONG time from now.
Haven't you read these posts about the 6-speed transmission. Not worth it IMO. Check the all-motor forum for information on the 3.5 swap, if by better you mean more powerful, then sure.
Originally Posted by THT
Use the 5spd for slightly more aggressive gearing. If you're feeling ambitious, use 1-3 gears from an 02 Altima for slightly better acceleration at the expense of fuel economy.
I stand corrected: http://forums.maxima.org/showpost.ph...3&postcount=28
If you're serious about doing this, you might as well bulletproof the gears before you put them in: cryo, shot peen (marginal benefit, these two), and deburr.
MAXSE5SPD
Sep 17, 2022 04:00 AM
RWCreative
Sep 21, 2015 11:01 AM
Violator
Sep 9, 2015 10:14 AM
