Trunk Vibration, with Structual Expanshion Foam.
Old Nov 6, 2005 | 05:48 PM
siren001's Avatar
Trunk Vibration, with Structual Expansion Foam. 56k BEWARE
Today I wanted to get rid of the vibrations of my trunk lid so i filled the top half except around the key hole and metal pully with structural expansion foam. the filler used in drywall repair. Anyone did that before
Trunk feels a lot more solid and heavier, drying right now so havent been able to test out.
Old Nov 6, 2005 | 07:09 PM
siren001's Avatar
pics comming soon, still drying looks like **** though with the foam leaked out of the cracks.
Old Nov 6, 2005 | 07:23 PM
siren001's Avatar
sorry looks like crap, got to wait to dry to cut down and sand smooth and paint.
Word for the wise if you use this stuff wear cloves, it eats away at your hands,
Old Nov 6, 2005 | 11:09 PM
wanaMax's Avatar
wow, that DOES look like crap, hopefully it cleans up nice. post later how it turns out.
Old Nov 7, 2005 | 03:23 AM
lalaMAX's Avatar
is that gonna fix the rattle from my 12 inch sub da made?
Old Nov 7, 2005 | 04:07 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
No, you need to add a mass loader.
Old Nov 7, 2005 | 09:50 AM
YuAnChen's Avatar
What is that ?
And how do i use it to stop the vibration form the sub ?
Old Nov 7, 2005 | 09:56 AM
filtor1's Avatar
Check out the deadener sticky in the audio forum.
Old Nov 7, 2005 | 10:43 PM
siren001's Avatar
started to work on it today, didnt take pics, no more tape, no more bubbling out of stuff, seems to do the trick, tested it out, go no vibrations from lid, looking at doing a major over haul on the trunk bought some sheet metal to cut and cover the big holes in the trunk, should be nice when all done,
Old Nov 9, 2005 | 12:11 AM
siren001's Avatar
update
Sorry process is slow, i dont work on it much with working 10-11 hour days
Old Nov 9, 2005 | 01:48 PM
Ephraim's Avatar
quite the inventive solution, keep us updated
Old Nov 9, 2005 | 02:42 PM
RA030726's Avatar
I'm nutty for Nissans
which did you use, the minimal expanding window foam, or the regular stuff?
Old Nov 10, 2005 | 01:06 AM
siren001's Avatar
I used some professional grade foam they use to put in light poles to insulate them. not sure what its called but it maked a big differnce no big air pockets like normal foam. get day off tomorrow so gonna try work on it. the trunk go thump when you bang or close it in stead of the light ting vibration kinda sound.
Old Nov 10, 2005 | 05:00 AM
Originally Posted by YuAnChen
What is that ?
A mass loader is a vibrational matt used to weigh a peice down in order to reduce flex. Like Chris said, check out the deadening sticky in the Audio forum.
It would look like this on the trunk...
Old Nov 10, 2005 | 08:20 AM
victor's Avatar
be careful not to put too much where the top (outside of your trunk) gets defermed. there is some really strong expanding foam out there.
Old Nov 10, 2005 | 07:02 PM
siren001's Avatar
Notice no more holes, like the one above, posted by metal max. put sheet metal over the holes except the one where the lock is, and mechanism's inside.
Old Nov 10, 2005 | 07:04 PM
siren001's Avatar
still going to layers of bondo to smooth out. so see no more layers, just prime every coat, because everthing rusts soo fast in hawaii.
REDinLV
Aug 15, 2024 12:30 AM
user 11122324
42
Jul 18, 2022 03:35 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
06maxima55
Sep 28, 2015 04:29 PM
Bonka
Sep 14, 2015 11:18 PM
