Car boggs down with AC on - what gives?
What could cause the throttle to get really " mushy " once the AC is turned on and car begins to accelerate?
With AC on , there is huge loss of power at take off, and i feel "flat spots" in power curve, car literally boggs down and forces me to turn AC off.
with AC off, things are back to normal.
anybody with similar issue?
Nick.
Nick.
yeah man thats pretty basic knowledge...any car with the ac on is gonna loose atleast 25% of its power ... the engine compensates less power to run the ac compressor and all the other stuff ... also looses a lot of gas milage with the ac on .. keep your windows down and enjoy the breeze !
All hands reading my thread, if you have an idea for solution please share it,
otherwise refrain from posting.
once again, my car boggs down with AC on
Nick.
Nick.
my friend, thats just the way the car is ... dosent this make sense, you said when you turn your AC off, it goes back to normal... I dont have that much power either with my AC on ... I dont think there is a soultion ?
It is normal and happens with every car... AC puts a constant load on your engine, it takes a good amount of power to run.
EDIT: I'd like to see a dyno run with AC on and off, that would be really interesting.
no, this is not the way the car is , I know the difference of power loss with or without AC after driving the car for close to 5 years. There was noticable loss of power before, but nothing like what is happening now- the car boggs down and refuses to accelerate. I'm suspecting my ac compressor clutch starting to seize up and thus placing greater load on the engine.
Nick.
Nick.
Nick.
Nick.
Never heard of anything like this happening before.
Good luck man. Sorry for the bland initial response.
Nick.
Nick.
I believe he made it VERY clear, in the beginning, that his car was doing more than simply experiencing a loss of power with the A/C on. With that said, I've been laboring with the very same condition on my '95 200SX SE-R (but not with the Max, fortunately), and I'm equally anxious to hear others' input. Good luck with the fix...
I have the same problem
car was fne one day and then it started doing that. I changed the ac compressor and the problem came back... I think I have a blockage in the AC Lines and thats putting extra load on the compressor.
Originally Posted by 99grnmaxgxe
lol jk, that is when you are going at a high speed, like highway speeds.... Nick, just go get your AC looked at to see what's wrong with it.
I had a similar problem with my Nissan truck years ago and it was a blockage in the AC lines. An AC shop replaced the dryer and expansion valve, cleaned the lines and replaced refrigerant (with my original). Cost $300 and worked fine afterwards.
Also check and see if the car has an idle up valve or similar device. This increases the idle when the AC is turned on and may not be working on your car. I'm not sure it has one, but think it does. Again my Nissan truck does.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
altome15
Aug 10, 2015 07:05 PM
dang , just quit saying this is normal because AC should not make your car bogg down and almost stall when accelerating from standstill
