Virbration in whole car
Old Nov 14, 2005 | 03:39 PM
97Se5spd's Avatar
Wen I drive from about 58mph and above, the car shakes, likes its out of alignment. The car was hit in the front before I bought it. Is it possilbe that it is just out of alignment, becuase my stearing is farily tight, or is it from the accident and is unfixiable unless I wanna spend big buxs?
Old Nov 14, 2005 | 03:55 PM
tavarish's Avatar
fwd gone rwd cr00
impossible to tell. Take it to a shop.
Old Nov 14, 2005 | 04:17 PM
maximariceboi's Avatar
possible alignment issue...or u need wheel balance? minor issues but if thats not it...$_$
Old Nov 14, 2005 | 04:26 PM
Dexter's Avatar
I'd say it's alignment but take it to a shop to be sure.
-Dex
Old Nov 14, 2005 | 04:28 PM
the_3d_man's Avatar
if it only does it at a certain speed then your wheels need to be balanced
Old Nov 14, 2005 | 04:40 PM
MDeezy's Avatar
Has the car recently started vibrating or has it been doing it since you've purchased it?
Vibrations could be:
Wheels need balancing
certain suspension parts worn out.
alignment out of spec.
examine your suspension and try to narrow it down, check for too much play in axle, check ball joint, look at bushings etc. . .
Old Nov 14, 2005 | 04:44 PM
ethnic6's Avatar
definately from the accident, my max was bought after an accident, it also shook, turns out the engine mount's frame was completely destroyed... had to have it welded, might not be the same issue with u, so unless u got a car lift, take it to a shop.
Old Nov 14, 2005 | 05:10 PM
kormax97
Cheapest way is to get your wheels balanced before anything.
Old Nov 14, 2005 | 06:17 PM
97Se5spd's Avatar
I checked the ball joints there good, and its does it like i said at 58mph and above, i havent checked the motor mounts or anything like that, but im gonna get it algined and balanced first. Any other things it could be? The car only has 57k by the way.
Old Nov 14, 2005 | 07:23 PM
Sounbwoy's Avatar
Make sure your tires are properly inflated...
Old Nov 14, 2005 | 07:27 PM
kormax97
Like I said before, balance the wheels first. It might save you the money and trouble of getting an alignment.
Old Nov 14, 2005 | 07:29 PM
Donald199's Avatar
Originally Posted by kormax97
....balance the wheels first. It might save you the money and trouble of getting an alignment.
True, also if there is ONE bent rim, it could cause the whole car to shake after certain speed. Have someone balance all the tires first, it cost like what 25 bucks for all four?
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
altome15
Aug 10, 2015 07:05 PM
