aksed my dealer about timing advance
Old Nov 15, 2005 | 02:53 PM
dennisuello's Avatar
I have a P0420 code that I need TSB done for. I also asked about doing a timing advance. Service guy said they will not do that, that they leave everything as factory set, due to some liability issues.
I will try another dealer, but it's 30 minutes away.
Old Nov 15, 2005 | 02:59 PM
SoonerFan's Avatar
Cletus
dont talk to the service manager or do it "on the record"
when i got mine done i talked directly to a service tech when he went out to get another car. gave him $50 and he did it. both of us won.
josh (irish44j) and I got our's done at the same time)
Old Nov 15, 2005 | 03:03 PM
Y2k2maxse's Avatar
what exactly is involved with a timing advance and what does it do? good for the car?
Old Nov 15, 2005 | 03:07 PM
NYPD-Arnold's Avatar
Z
I've noticed that on 3.0L 5th gens, BTDC @ 17 gives an incredible surge of power. On the 3.5L 5th gens not so much.
Old Nov 15, 2005 | 03:08 PM
irish44j's Avatar
retired moderator
like sooner said, just find a tech out taking a smoke and slip him some cash to do it real quick....
make sure to bring the programming instructions (posted here someplace) to show him when he tries to say "I don't know how to do that" etc etc...
Old Nov 15, 2005 | 03:09 PM
SoonerFan's Avatar
Cletus
i dont know what its supposed to do. i just did it cause josh was doing it...peer pressure
irish44j's Avatar
retired moderator
that is the impression when me (3.0) and sooonerfan (3.5) had when we got ours done at the same time.
though, "incredible" might be a bit strong of a word
Old Nov 15, 2005 | 03:11 PM
Y2k2maxse's Avatar
but is it bad for the engine?
Old Nov 15, 2005 | 03:14 PM
irish44j's Avatar
retired moderator
no
10char
anyone has a link to instructions?
Old Nov 15, 2005 | 03:20 PM
Puppetmaster's Avatar
The Stickies do:
http://forums.maxima.org/showthread....timing+advance
Old Nov 15, 2005 | 04:12 PM
Z
Not for me it isn't. When I had my timing bumped up to 17, I didn't even know what it was for. My friend at Star Nissan just did it for me, told me to run only 93 from now on (which I always did anyways) and told me to call him later on. Needless to say, I needed to get ahead of some assh*le who wouldn't let me in a lane, and when I stomped it, I had NO idea what the hell to expect. All of a sudden the car just shifted and took off so hard that I vividly remember yelling to myself "WHAT THE F*CK WAS THAT!?" No joke. I actually screamed that out. I was in utter shock, it gave me a heavy foot since then. =)
Shame that the 3.5s don't experience this as much as we do.
Old Nov 15, 2005 | 04:14 PM
Z
Instructions:
http://forums.maxima.org/showpost.ph...90&postcount=1
Sometimes I like to credit myself for helping to really bring the timing advance craze to the masses. I've gotten well over 200 PMs asking me about it and where to get it done.
Old Nov 15, 2005 | 04:20 PM
DrKlop's Avatar
Driving is the next best thing
no
But doesn't it put more stress on the engine internals?
Old Nov 15, 2005 | 04:24 PM
SoonerFan's Avatar
Cletus
no..................
Old Nov 15, 2005 | 04:29 PM
DrKlop's Avatar
in this case, could someone explain how it works?
oh and two more questions:
Does the fuel economy decrease?
How much extra HP do you get from this on VQ30?
Old Nov 15, 2005 | 04:31 PM
SoonerFan's Avatar
Cletus
do a little research. this has been discussed A LOT!! no one wants to spend the time to explain everything again.
donating will make your search easier
Old Nov 15, 2005 | 04:36 PM
DrKlop's Avatar
For the time I’ve been a member it was not discussed for sure. Besides, it’ll take at least 20 minutes for me to find this info and someone who knows it can type it in 20 seconds…
So if someone knows the answers to my previous post please let me know.
Old Nov 15, 2005 | 04:40 PM
SoonerFan's Avatar
Cletus
20 minutes to find the answer
or
30 seconds to donate then 30 seconds to search
Old Nov 15, 2005 | 04:43 PM
SoonerFan's Avatar
Cletus
fyi,
i just did a search and there have been 10 threads since jun 05 (when you joined) that answers your question
Old Nov 15, 2005 | 04:44 PM
DrKlop's Avatar
or
Or 20 seconds of your time (which you have just spent anyways) to save me $25…
Anyways it’s up to you…not you, then someone else
Old Nov 15, 2005 | 04:46 PM
SoonerFan's Avatar
Cletus
well if you think you are just donating to answer this one question, then dont donate. i'm sure you will never need to search for something again...when you can just post the question
Old Nov 15, 2005 | 04:47 PM
Z
Basically, when advancing timing you're advancing the point at which spark is created. The earlier the spark, the quicker the power is made and put down to the wheels -- this is also called "Before Top Dead Center" or BTDC. As far as HP increases, it's around the neighborhood of ~5HP per degree -- though this is open for debate.
Fuel economy actually increases as long as you only use 91/93 octane. But you probably won't see much of an increase since you'll likely develop a heavier foot from always wanting to feel the increased surge of power -- I know I did.
On 3.5Ls it doesn't make much of a difference because of how the 3.5L was designed. 3.5Ls are more prone to engine knock from low grade octanes than the 3.0Ls, which might mean that they're already running a certain timing that'll create knock easier. 3.0Ls will require a lot more abuse and poor octane to begin knocking.
Err...I guess if I'm not coming off clear, let's put it this way: the 3.5Ls 15-degrees is like a 3.0Ls 17-degrees. So when 3.5Ls are advanced it doesn't do much for them, because they're already built from the factory to spark quicker/early, where as 3.0Ls have to be advanced to do this. This is what I was told previously by a Nissan technician. It sort of makes sense* once you begin to consider the frequent engine knock issues people have with their 3.5s.
*Edit: I have NO idea how I wrote "noise" instead of "sense".
Old Nov 15, 2005 | 04:51 PM
they seemed to be talking about it a lot back in 2002 already.
http://forums.maxima.org/showthread....advance+timing
Old Nov 15, 2005 | 04:53 PM
DrKlop's Avatar
Err...I guess if I'm not coming off clear, let's put it this way: the 3.5Ls 15-degrees is like a 3.0Ls 17-degrees. So when 3.5Ls are advanced it doesn't do much for them, because they're already built from the factory to spark quicker/early, where as 3.0Ls have to be advanced to do this. This is what I was told previously by a Nissan technician. It sort of makes noise once you begin to consider the frequent engine knock issues people have with their 3.5s.
Thanks, that’s basically what I wanted to find out
Old Nov 15, 2005 | 04:56 PM
http://www.howstuffworks.com/ignition-system1.htm
http://forums.maxima.org/showpost.ph...9&postcount=20
People need to flippin search.... use the Google, donate, or just read through the old threads.
/thread
Old Nov 15, 2005 | 05:00 PM
irish44j's Avatar
retired moderator
Originally Posted by Puppetmaster
doesn't look like you're "studyin" like your IM says
Old Nov 15, 2005 | 05:05 PM
SoonerFan's Avatar
Cletus
if people spoon feed them they wont ever need to search
Old Nov 15, 2005 | 05:48 PM
Z
Yep, I know. Then it went dead for a while. Then I started raving about it and half of the tri-state here started PMing me about where Star Nissan was located and what was the name of the guy, etc. etc. It seems like it was sort of ressurected. My 200 PMs figure could actually be too little...that's how often I was getting PMs from people about it. :P
AnsonJ
Jun 2, 2017 01:35 PM
Ben2003GLE
31
Jul 17, 2016 08:13 AM
Starrider
Sep 17, 2015 07:26 AM
305head
Aug 26, 2015 09:03 PM
Tanvirkamal
Aug 5, 2015 01:32 AM
