trouble starting when warm?
Old Nov 17, 2005 | 06:10 PM
4dscPat's Avatar
This started after I replaced my timing belt last week. The car starts fine if it hasnt been started in over an hour or so. It it's warm though, it will crank but not fire. I have to keep trying for a few minutes to get it to fire. Any idea what could be wrong? Last time it happened I'm pretty sure I saw grayish smoke waft up from the tailpipe.
Old Nov 17, 2005 | 06:13 PM
Alex_V
hows it idle air control valve? id pull a plug or 2 and see how they look. mine was like that and i got 6 new free spark plugs and that helped, but changing my iacv with a spare fixed it up. I also cleaned it before i put it on.
~Alex
Old Nov 17, 2005 | 06:17 PM
4dscPat's Avatar
Hmm, my idle is often inconsistant. Would that keep it from starting? When it does finally fire, i have to give it gas for a second or two to keep it from dying.
Old Nov 17, 2005 | 06:20 PM
Dillbag's Avatar
Suprise butsechs!!!
yeah, sounds sorta like the IACV.
Old Nov 17, 2005 | 07:03 PM
decus's Avatar
Run ECU codes, could be a lot of things.
My guess would be CHTS. Seeing as it happened after the timing belt, you may have knocked the connector off/something. The CHTS is not used by the ECU when the engine is cold (closed loop)....hmm, i dont know. just a guess
Old Nov 17, 2005 | 08:31 PM
4dscPat's Avatar
Whats the CHTS?
Old Nov 17, 2005 | 08:41 PM
decus's Avatar
Cylinder head temperature sensor, code 13 when u run the ecu codes.
Old Nov 17, 2005 | 10:40 PM
Cliff Clavin's Avatar
Way out West
usually if you look it up as a part it will be under coolant temp sensor. They are like $20 at NAPA. When mine went out, it did throw a code 13.
Old Nov 17, 2005 | 11:31 PM
decus's Avatar
Yeah, you have to be careful to get the right one. There is a CHTS which is at the front of the motor and another coolant sensor.
Old Nov 18, 2005 | 01:03 AM
Greeny's Avatar
¯\(°_o)/¯
Being you just replaced the t belt im thinking your timing is off a little...
Old Nov 18, 2005 | 07:00 AM
Grace_Imports's Avatar
Open loop is cold...closed loop is after warmup
Old Nov 18, 2005 | 07:15 AM
internetautomar's Avatar
mod or sell?
the CHTS is what tells the car when to change "loops"
Old Nov 18, 2005 | 07:18 AM
maximapitko's Avatar
The Bulgarian Guy
my bet would be water temp sensor like a few people above...
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
markevans999
Sep 10, 2015 04:29 PM
trungg86
Sep 4, 2015 04:58 AM
