rpm switch connection quick please
You mean to get the RPM signal? You can either use the TAM screw behind the instrument cluster or the RPM signal wire on the ECU harness. I personally used the RPM signal wire on the ECU harness. Check your FSM or Haynes or Chiltons to find out what color it is.
shilov
Feb 19, 2024 09:40 PM
James92SE
Oct 8, 2015 04:57 PM
