digital rear view install write up??
Old Nov 22, 2005 | 01:45 PM
Battle Max's Avatar
Disclaimer: i have searched for the past 2 hours and cant find anything on a write up.
Im looking for meaningless but cool things to upgrade my base model 02 se and i definetly like the look of the digital rear view mirrior. How hard is the install for something like that plug and play or too much wiring and not worth the trouble??
Thanks.
Old Nov 22, 2005 | 01:52 PM
1992sc50's Avatar
That sounds sweet. I'd like to see somthing like that too. Anyone have any info?
Old Nov 22, 2005 | 01:58 PM
TXT-1's Avatar
Digital rearview mirror? Are you talking about the digital compass in the rearview?
Old Nov 22, 2005 | 02:28 PM
Battle Max's Avatar
yessir......
Compass temp guage.
Old Nov 22, 2005 | 02:32 PM
SoonerFan's Avatar
Cletus
Originally Posted by Team Falken
yessir......
Compass temp guage.
the TEs have a compass but not temp.
Old Nov 22, 2005 | 02:34 PM
Battle Max's Avatar
I stand corrected sir. Still no install help though..
Old Nov 22, 2005 | 03:01 PM
Stardust's Avatar
F---ing Kangaroos
Don't they have the temp on the dash?
Old Nov 22, 2005 | 03:09 PM
OOmaxSE's Avatar
don't all 5.5g have temps on the cluster? last time i checked...
Old Nov 22, 2005 | 03:17 PM
Larrio's Avatar
The Definitive AE Master
check hnda_etr's website
He installed a digital rear view mirror with compass and auto dim on this car
Old Nov 22, 2005 | 03:28 PM
Battle Max's Avatar
Thanks Larry...
Old Nov 22, 2005 | 03:32 PM
Puppetmaster's Avatar
Someone did a rear view with a compass from a Camry recently... his thread is still on the 2nd or 3rd page... try asking him as well.
Old Nov 22, 2005 | 03:44 PM
OHH NOES's Avatar
6spd Swapped
The mirror is plug and play, disconnect the old and connect the new. Thats why there arent any write ups
Old Nov 22, 2005 | 05:37 PM
MIXXMAX's Avatar
I have a rear view mirror with temp. and compass installed in my car. PM me if you need help on install write-up. It's not hard at all.
Old Nov 22, 2005 | 07:04 PM
bugbite77's Avatar
it is direct plug and play, just unscrew the tock mirror off and slide the compass titanium edition mirror on, and plug in the same stock wireing harness.
Old Nov 22, 2005 | 07:15 PM
SoonerFan's Avatar
Cletus
i realize that..i have an 02. i was simply saying that it isnt on the mirror
Old Nov 22, 2005 | 07:20 PM
TrojanMan2116's Avatar
I think he has a plain old mirror on base models like stated. (no wiring at all) and would like to know how many wires will need to be run up there. I also could use that information since i have the boring stock mirror with no power at all.
Old Nov 22, 2005 | 07:35 PM
MIXXMAX's Avatar
The auto dim mirrors only need a two wire hook-up...power and ground. Same goes for the ones with compass. The ones with temperature need a sensor probe which requires another two wire hookup. Cars, such as mine, did not come with auto dim. I had to run wires for power, ground, and sensor for mine to function. It's best to tap into ignition for power so that mirror powers all the time while car is on.
Old Nov 22, 2005 | 08:08 PM
OOmaxSE's Avatar
i'm on the same boat as you. 2000 max with nothing on the rear view.
so you have auto dim, compass, and temp sensor???
what was included with your rearview mirror??? or did you do a "custom" wiring?
Old Nov 22, 2005 | 08:18 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
I have the auto dim, can I add the TE rear mirror to an 01? is it plug and play ?
Old Nov 22, 2005 | 09:46 PM
MIXXMAX's Avatar
Yes, I had to custom and re-wire everything including running a temp. sensor for my mirror. Look at my pic in post #13. There were no wiring for plug-n-play since my car came with just a plain rear view mirror.
Old Nov 22, 2005 | 09:51 PM
OHH NOES's Avatar
6spd Swapped
He has an 02 max, and im almost 100% positive they all came with the auto dim mirror meaning he wouldnt need to run any wires. I dont know off hand how many wires though...
Old Nov 22, 2005 | 10:18 PM
Battle Max's Avatar
Correct i have the autodim feature that i dont even know how to work.. So basically i see its plug and play. Thanks for the advise fellas i may take on that challenge soon.
Old Nov 23, 2005 | 08:36 AM
Stardust's Avatar
F---ing Kangaroos
Joke............
Old Nov 23, 2005 | 10:58 AM
bugbite77's Avatar
If the green light is on on the mirror, it will auto dim, if you push the mirror button , and the green light goes off, it will not auto dim, and if you have this autodim mirror stock, the compass/autodim mirror is a direct replacement.
Old Nov 23, 2005 | 11:15 AM
Battle Max's Avatar
Thanks man.
Old Nov 23, 2005 | 09:50 PM
danger300z's Avatar
what about the 03 altimas they have an compas mirror as well . Has anyone install a altima compas mirror and is it plug an play as well?
JRod28
Feb 4, 2016 11:07 AM
Huttig2009
Sep 25, 2015 03:31 PM
Maxilano
Aug 31, 2015 07:33 PM
BobMax
Aug 19, 2015 04:39 PM
