How many quarts of ATF do I need?
Old Nov 25, 2005 | 01:52 PM
MaDMvD's Avatar
I just bought a gallon of AMSoil (4 quarts), and the guy says that Maximas use 10 quarts. Is this true? Please advise - thank you!
Old Nov 25, 2005 | 02:16 PM
njmaxseltd's Avatar
If your only doing a drain and refill, 4 qts (1 gallon) should be fine.
A flush requires a case (12 qts).
Refer to the fluids and lubricants section of this site for more info on changing your tranny fluid. The stickies on that forum has some good information.
Old Nov 25, 2005 | 04:05 PM
TurTLe*'s Avatar
^yep. normally there is about 4 quarts in the pan, about 5 quarts in the torque converter and about 1 quart hanging around somewhere. If your just going to drop the pan, your going to need about 4 quarts.
in the lube section they have a write-up on how to do a flush urself on a 4th gen takes about 10-12 quarts pending how clean you want it.
A lot of ppl are against mixing syn and dino oils. But i ask amsoil themselves and they say its prefectly normal. Should be no problem. When it gets warm out, i'm just going to do a drain and fill every month for 3 months and hopefully i'll get out about 75% of the junk fluid.
Old Nov 25, 2005 | 06:55 PM
MaDMvD's Avatar
Wow - excellent replies. Thank you both for such great input!
Sincerely,
Maurice
Old Nov 29, 2005 | 03:15 AM
FishyMan's Avatar
im just curious how u get an accurate. reading.
Old Nov 29, 2005 | 04:17 AM
njmaxseltd's Avatar
Get the tranny up to operating temp by driving it about 5 miles.
Car on level ground, engine running in park, pull the dip stick and look at the level.
There are 2 marks, one says cold, the upper one says hot. It's always best to check it hot.
rbuswell
Nov 17, 2016 04:54 AM
foodmanry
Sep 24, 2015 12:02 PM
pjgreek
Sep 9, 2015 09:30 PM
mclasser
Aug 23, 2015 09:32 PM
bill99gxe
Aug 23, 2000 11:28 AM
