Need help on vacuum lines...
Old Nov 26, 2005 | 07:39 AM
MaXtUneD's Avatar
VE30DE DOHC Motor....
Hey, I took a picture of this part:
Do you see the 2 hoses that runs to the left connected to something...Don't worry about the one on top that is open..I took off the hose so that you guys can see clearly..AND the hose at the bottom..Don't worry about that..I'm just talking about the 2 hoses in the middle Parallel to each other...Now my concern is the bottom hose..When I take off the hose when the car is on, nothing happens..Their is no vacuum in that line..is that a bleeder?Because I connected a vacuum line to that..Nothing strange happens when the car is ran..
Here is another pic farther away...
Anyone car to give me a schematic on on these vacuum line are ran in stock form...
NOTE: Since I have the variable Intake system..You know the actuator on the passenger side, Isn't that a vacuum source? Because When I take off the hose, I get no Vacuum..
Old Nov 26, 2005 | 08:00 AM
Mizeree_X's Avatar
Getting back to his roots
Why don't you photoshop arrows to point to what you are referring to? All I can say is that those two solenoids are the EGR and VIS solenoids, and so the output vacuum lines will only have access to the vacuum source when the ECU triggers the solenoids to open.
Old Nov 26, 2005 | 12:01 PM
«§»Craig B«§»'s Avatar
yeah, like he said, those are EGR and power valve solenoids. So they wont always have vacuum, only under certain conditions dictated by the ECU
Old Nov 26, 2005 | 04:02 PM
Phoenix's Avatar
Lives in a Maxima
Hope this helps!
Old Nov 26, 2005 | 05:03 PM
internetautomar's Avatar
mod or sell?
DANG those are way too big of pics.
Old Nov 27, 2005 | 07:26 AM
Mizeree_X's Avatar
Originally Posted by redSeraph
Hope this helps!
That's a pic of a 4th gen vacuum diagram.....we don't have an absolute pressure sensor or an EVAP canister purge control valve (at least not in that location).
Old Nov 29, 2005 | 12:41 PM
Jeff92se's Avatar
I'm needing a caw
I don't know how many times I've suggested looking at the autozone link. To red, Autozone mislabeled the pics. Nice try though.
Old Nov 29, 2005 | 02:13 PM
MrGone's Avatar
Brown = EGR
Green = Power Valve
The firewall side ports (the ones with the arrows pointing towards them) are the inlets for the solenoids. The EGR gets it's 'vacuum' from before the throttle plate in the throttle body. The Power Valve gets it's vacuum from the vacuum canister, which gets it's vacuum from the plenum. There is a one way check valve going between the plenum and the vacuum canister, it will not allow air to enter the vacuum canister.
The best place to tap for vacuum ports would be right before the vacuum canister IMHO.
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
conansriver
Nov 18, 2015 02:46 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
cruce91
Sep 20, 2015 10:23 AM
N2deep
Aug 16, 2015 08:30 PM
